Fault code P0118-002 engine coolant temp sensor G62
Varks
Post by Varks » Sat Jan 25, 2025 2:55 pm
Hi all, could someone shed some light on a couple of issues I have, not sure if it’s to do with the same thing or not, I got the engine coolant sensor signal too high fault and I changed the green temp sensor at the rear of the engine on the passenger side, I still have the same fault and I still have a very noisy fan that comes on as soon as I start the car, is there another temp sensor I need to change instead, is there also a separate issue as to why the fan is continuously running,
Thanks again 👍
Renault 4 GT Turbo, Series 2 RS Turbo, 90 sport 2.3 20v 5 pot, Subaru Legacy GTB, several A4 S-Line 170's 3.0 tdi Le Mans, 2 x B5 S4, 2003 C5 RS6 in Daytona- 8 pots, 4 Rings!!! :blackrs4:
Re: Fault code P0118-002 engine coolant temp sensor G62
Post by Shoppinit » Sat Jan 25, 2025 2:57 pm
Is it an OE sensor?
What's the exact code you are getting?
Varks
Post by Varks » Sat Jan 25, 2025 3:07 pm
Shop, cheers for the quick reply, just did another auto scan post clearing the DTC and it’s now gone, so thankfully the new sensor has solved that problem (also found a broken signal wire in the passenger MAF, so sorted that out too, anyway back the the fan issue, the only faults I have linked to any of the fans is the following :
2 Faults Found:
00819 - High Pressure Sensor (G65)
29-00 - Short to Ground
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
Where do I start lol
Post by Shoppinit » Sat Jan 25, 2025 3:15 pm
The high pressure sensor is for the AC so that could be putting your fan on full. It's easy to replace.
You can ignore the air quality sensor DTC.
Post by Shoppinit » Sat Jan 25, 2025 3:22 pm
Original part number: 8E0959126 now replaced with 3R0959126
e.g. https://www.autodoc.co.uk/spares-search ... B%5D=10223
or https://www.autodoc.co.uk/spares-search ... %5B%5D=312
They should come with the o-ring but if not it's part number 7H0820896. https://www.autodoc.co.uk/topran/8208921
Varks
Post by Varks » Sat Jan 25, 2025 3:29 pm
Cheers buddy much appreciated :thumb: :thumb:
TOPMAN
Post by TOPMAN » Mon Jan 27, 2025 2:52 pm
Hi Lee
Before ordering the new part of check that the plug is properly connected. My plug wasn’t broken earlier this summer, but I noticed it was a bit weak, so I bodged it with some cable ties until I resin a new plug. When that plug is disconnected, the fan comes on straight away after the key is turned Image I think the plug gets weak from repeat disconnects from the front carrier removal.
RegardsImage
Craig
cover99
Post by cover99 » Mon Jan 27, 2025 9:20 pm
Hi Lee
RegardsImage
Craig
Hi Craig could I trouble you with a couple of questions.
1. Did this connector being loose result in both fans coming on or only the smaller fan when the key is turned.
2. Is it actually possible to get a hand on this without the bumper off. I believe i can see it next the the headlight with a torch?
Thanks Again
Steve
bilko1
Post by bilko1 » Tue Jan 28, 2025 10:33 pm
Both fans come on full blast, I had the front end off mine tilted forward to do the cambelt. As soon as I started the car fans came on as the air con pressure sensor is disconnected.
cover99
Post by cover99 » Tue Jan 28, 2025 11:02 pm
Really appreciate this. Looks like it could be my next move as now pulling out my hair!!! well any that i have left.
Varks
Post by Varks » Wed Jan 29, 2025 5:44 pm
Craig, cheers for that buddy,
So not had a chance to get on the car yet due to the weather and work, I ordered a new sensor anyway as whilst I have the bumper etc off and the tine to do it I didn’t want to get stuck waiting in case it was the sensor after all, I will definitely check the plug first though, 👍
