Lemforder Top Arms
Mɐʇʇ
Lemforder Top Arms
Post by Mɐʇʇ » Thu Jan 12, 2023 10:32 pm
Is anyone able to confirm the exact lemforder part numbers for the front upper arms please?
Why?
Because if I look up the Audi part number and cross reference it, I get a different set of numbers than I do if I use the AUTODOC and ECP parts lookup against our cars.
So I’m now confused.
Re: Lemforder Top Arms
Post by Shoppinit » Fri Jan 13, 2023 9:06 am
Have you tried the Lemforder catalogue?
https://aftermarket.zf.com/go/en/lemfoe ... 1,1334,771
Mɐʇʇ
Post by Mɐʇʇ » Fri Jan 13, 2023 4:30 pm
I did.
Lemforder's catalogue lists 21030 01 as a compatible part with the RS6.
But lemforders Audi x-ref part numbers for this part does not include 8E0 407 509 P
And if I then search for 8E0 407 509 P on the lemforder site, I get lemforder part number 21613 01, which does have the RS6 part number as a cross reference
Both listed as an upper front right control arm.
Any clue?
Mɐʇʇ
Post by Mɐʇʇ » Fri Jan 13, 2023 9:49 pm
So you’ve got the ones that cross reference based on part number, not their parts guide. I assume they fitted and all is good with them?
Mɐʇʇ
Post by Mɐʇʇ » Fri Jan 13, 2023 9:58 pm
Anyway. Ordered. Same ones as you. Thank you. :)
Astrosquirrel
Post by Astrosquirrel » Sat Jan 14, 2023 1:40 pm
Fit like a glove and visually exact match :). I matched them through part # from 7 zap and AutoDoc. Look also the same as the ones on my 2003 RS6 donor.
Mɐʇʇ
Post by Mɐʇʇ » Sat Jan 14, 2023 10:16 pm
Yeah, I always use part number x-ref, but this time came up with different numbers, which was odd. Anyway, all on order and looking forward to wrestling with the pinch bolt
Astrosquirrel
Post by Astrosquirrel » Sun Jan 15, 2023 1:50 pm
In my experience the easiest way to remove the pinch bolt if stuck is:
1) Cut it as close as you can to the housing
2) Drill a hole in the center of the bolt
3) Air hammer it out with the pointy bit
Good luck :)
Mɐʇʇ
Post by Mɐʇʇ » Tue Feb 21, 2023 6:17 pm
All done with the lemforder arms as listed above. Also did the front ARB drop links at the same time - and as above, lemforder are the OEM (Audi logo is ground off). I got the drop links from ECP:
* https://www.eurocarparts.com/search/610441165
* https://www.eurocarparts.com/search/610440935
Users browsing this forum: ChrisA, srichards and 69 guests
