Front wheel bearings
Foxmeister
Post by Foxmeister » Sun Jan 29, 2023 12:32 pm
Definitely needing the drivers side done now as I’m getting quite a drone when steering left and weight is on the drivers hub, don’t leave your car for long periods kids :roll:
Anyway, I’ll get both front done as I’m sure these could well be original with mileage etc
Are these press in/out type bearings though, or can they be done without means of a mechanical press? I’m sure SKF had a kit with flange attached previously, but they don’t list it now from what I can see
I don’t have access to that kind of equipment so just to see if I need to book it in with a local garage instead
Also, any recommended bearings other than SKF that will be good quaility people have used?
bilko1
Re: Front wheel bearings
Post by bilko1 » Sun Jan 29, 2023 7:30 pm
They bolt in from the rear of the hub, use a decent quality tool as the heads are shallow.
Mɐʇʇ
Post by Mɐʇʇ » Sun Jan 29, 2023 7:54 pm
Generally if an SKF is available, I go out of my way to use it, I don’t go looking for others.
Post by Shoppinit » Sun Jan 29, 2023 8:06 pm
^Totally this
Foxmeister
Post by Foxmeister » Sun Jan 29, 2023 9:57 pm
The problem is they only stock them without the flange, I’m sure they done them with before
https://vehicleaftermarket.skf.com/uk/e ... s/VKBA3536
How does the flange remove, will I need a puller? Likely a garage job as I don’t have one to hand
bilko1
Post by bilko1 » Mon Jan 30, 2023 3:25 pm
Puller or press or suitable size drift / socket and it should tap out. I don't remember any dramas doing mine.
Users browsing this forum: Google Adsense [Bot] and 73 guests
