Good Afternoon All,
I need to get hold of a second hand RS6 C5 19"x9" OE 5 SPOKE RONAL ALLOY WHEEL URGENTLY.
I already have 3 wheels- I just need a forth one.
I'm not concerned about the condition of it (as it will be powder coated straight away) as long as its not buckled or cracked. Also a new tyre will be going on it to - so if tyre is bald that is fine!
I'm based West London, UK and can pick up if not too far away.
Pls can someone help?
James
RS6C5 19"x9" OE RONAL 5 SPOKE ALLOY WHEEL REQ ASAP
RS6C5AVANT81
Steve2003rs6
Re: RS6C5 19"x9" OE RONAL 5 SPOKE ALLOY WHEEL REQ ASAP
I might be in a position to help. Not sure if they are 9 or 8.5. They were the original wheels off my c5.
My new set are 9,s
Will check sizes when I get home. If the sizes are right I will send a photo.
Before I removed them. They were checked and powder coated. I am on the east coast.
I use one as my spare
Two are available in good condition
One had a small split and was repaired.
My new set are 9,s
RS6C5AVANT81
Brill thanks for info. Look forward to hearing from you.
Cheers again
James
Cheers again
James
Steve2003rs6
Just remembered. The reason I removed them from my car.
The fronts were fitted with 5mm spacers when I bought the car.
IIRC without the spacers the front wheels would foul on the calipers.
I personally hated the spacers. So by chance a set of Audi wheels came up for sale at a very reasonable price.
Job done and no spacers.
I will get the wheel size and et size for you so you can compare with your existing alloys.
RS6C5AVANT81
Steve2003rs6
Hi James. Sorry mate my originals are 19x8 et35.
As previously stated my new ones are 19x9.
RS6C5AVANT81
Ah ok no probs- thanks for checking !
