Red engine loom connector T17k pin out?
AshD2S8
Post by AshD2S8 » Tue Dec 28, 2021 7:44 pm
Does anyone know what wires do what in the red engine side connector T17k?
Elsa has a different pin out for what I have on the engine loom, I’ve checked it against 3 rs6 looms I have in the workshop, all the same on the red connector… go Elsa and 7 of the wires are different and it also states can wiring is involved… can’t find any variants that have the correct diagram?
Help needed for my conversion.
Many thanks
Ash
Re: Red engine loom connector T17k pin out?
Post by Shoppinit » Thu Dec 30, 2021 12:04 pm
Lots of stuff going through that connector. AC, Airbags, TCU comms, fuel pump module comms.
What are you looking for exactly? Which wires are different?
AshD2S8
Post by AshD2S8 » Fri Dec 31, 2021 1:16 am
Thanks for the reply, I’m after what pin 13/14 does, after some research I have managed to trace the rest, but pin 13/14 are a yellow wire and a green wire which go into a sheath then into the main wiring harness, after it comes out of the gromit for the electrical box it is with about 6/7 sheathed wires all seperate from another.
Many thanks,
Post by Shoppinit » Sun Jan 02, 2022 11:09 am
Those yellow and green wires go to the TCU for CAN comms.
On the other side of the T17k connector they turn into orange/black and orange/brown respectively. They stay that colour until they get to the TCU.
AshD2S8
Post by AshD2S8 » Sun Jan 02, 2022 7:15 pm
Ahhh makes sense, the wiring pic I was looking at was only telling me it was the orange and black can wires, does it show you exactly what it goes into for the TCU? Chances are I won’t need them as it’s a manual swap into a d2 S8
Post by Shoppinit » Sun Jan 02, 2022 7:32 pm
Yeah. What do you need? The pins on the TCU? Looks like it might go onto a bus with potentially other CAN consumers, possibly instruments amongst others. Need to dig a bit deeper.
