C5 RS6 ECU Pinouts/Diagrams?!
jolio1994
Post by jolio1994 » Tue Mar 10, 2020 7:17 am
Currently finishing up my BCY swap into my '95 S6 Avant. I've found a few pinout diagrams for the ECU here and there, but haven't been ale to find anything solid...
Does anybody have the Pinout's for the ME7.1.1 ECU aswell as the connectors that plugin from the engine loom into the chassis harness?
Gracias :jump:
Image20200308_162900 by Joel Francisco
Re: C5 RS6 ECU Pinouts/Diagrams?!
Post by 8520 » Tue Mar 10, 2020 6:34 pm
Joel,
I have some of this info. I thought I had emailed it to you before, but I just did again.
You’ll need to be able to read track diagrams
03 RS6 sedan V8TT, 03 S6 Avant V8, 06 Touareg V8, 03 Silverado V8
All V8’s in my garage because America :mrgreen:
jolio1994
Post by jolio1994 » Thu Mar 12, 2020 6:30 am
I've been slaving over it Andre, thanks for the diagrams.
I've managed to narrow down the necessities of what's need down to the OBD2, drive by wire, fuel pump/injectors, and terminal 15/30 + grounds.
Tomorrow I'll cut everything else I don't need and finish the in car harness. Again, big thanks! The one really unknown I had was where VSS goes in from. It doesnt look like the ECU even see's VSS unless it's from the CANBUS or another undisclosed location (which I cant find)
Image2020-03-12_01-17-56 by Joel Francisco
Post by 8520 » Thu Mar 12, 2020 4:08 pm
From what I remember, the VSS goes from the sensor directly to the cluster, and then out to the ecu. Email me back. I pinned out the plenum harness for an 02 s6 a while back when I did my 2.7 swap and a lot of the basic stuff should carry over.
birotore
Post by birotore » Wed Oct 27, 2021 10:10 pm
hi guys !! i'm making a swap with an rs6 motor..I have to understand how to power the ecu, and which wires to connect to start the engine, in a racing chassis! can someone help me? my number is 00393663288482 also whatsapp or birotore @ gmail.com
Users browsing this forum: No registered users and 105 guests
