Advice Please
Re: Advice Please
I discussed the fitment of the pipes with unit 20 a while back. They can be done with engine in situ. But a bit of a pain to do.
Re: Advice Please
Right i have tasted the liquid tonight that has been slowly leaking under the car and I am pleased to report that it was very sweet, which I take means that it is coolant and not oil.
I have checked the coolant level and it was basically on the max line so it can’t be a major leak ?
Still coming from the front right hand side tho, so any ideas as to what it could be or where to look ? Hoping to get it up on the ramp this Sunday to have a proper look under it.
P.S. happy Friday everyone!
Re: Advice Please
That’s where the oil filter housing / heat exchanger is. Poosey pipe, innit? If I were you I’d snap Steve’s arm off.
Re: Advice Please
it's good that it's not a major e.g. enough to effect the pressure capacity of the system. But don't wait to fix it, if/when it becomes a bad leak....
Re: Advice Please
Ok sound, well in that case I think I will buy one off Steve and get in contact with MRC and see if they can help me out with the fitment as they are only 2 hours away from me. Guessing I am going to be looking at a fairly large bill with it being an engine out job
Re: Advice Please
Another poosey pipe on its way to Ireland.
Thank you Simon.
Thank you Simon.
Re: Advice Please
Please could I buy a replacement pipe Steve ?steve2003rs6 wrote: ↑Sat Sep 18, 2021 4:02 pmAnother poosey pipe on its way to Ireland.
Thank you Simon.
Re: Advice Please
Yes mate. Will send you a pm.
And another poosey pipe sent.
Re: Advice Please
It’s not a engine out job. Unit 20 have done lots with engine in situ.beatsyrs6 wrote: ↑Sat Sep 18, 2021 3:05 pmOk sound, well in that case I think I will buy one off Steve and get in contact with MRC and see if they can help me out with the fitment as they are only 2 hours away from me. Guessing I am going to be looking at a fairly large bill with it being an engine out job![]()
Re: Advice Please
Grizz did mine while I waited, it was a long wait
Re: Advice Please
If you have axillary radiators behind the intercoolers check them and the hoses for leaks as well.
Re: Advice Please
Mine had the same coolant leak, passenger side front bumper, turned out it was the auxiliary radiator which I have taken off to get repaired in the meantime I have run a pipe connecting inlet and outlet.
Re: Advice Please
It makes me smile every time I see call that pipe by it's correct name.
Re: Advice Please
Which one makes you smile Matt
Bufkin pipe
Poosey pipe.
It surprised me how many pipes were sent.
Only a small amount left from the 24 that were manufactured.
Even though they were made to the original drawing dimensions.
I will feel a lot better when someone has installed one.
As this will be the true test that they are ok.
Bufkin pipe
Poosey pipe.
Re: Advice Please
Poosey pipe, obvs. You've picked up the mantle
Users browsing this forum: 111marc111, Google Adsense [Bot] and 81 guests
