ABS light and gearbox issue P0501 code
Gareth1984
Re: ABS light and gearbox issue P0501 code
Post by Gareth1984 » Wed May 20, 2020 12:36 am
That makes a lot of sense considering my wiring has been butchered. I’m praying for good news and hopefully not another huge bill 🤦‍♂️
Thanks again for the advice
simonpoulton
Post by simonpoulton » Wed May 20, 2020 2:22 pm
Also regarding your original issue with the MAF wiring, my bet is the plug had crumbled (they will be doing that at this age) and for some reason they didn't just replace the plug. I've switched both of mine as they take a bit of abuse when taking the airbox on and off.
Past: R56 Mini Cooper S
Gareth1984
Post by Gareth1984 » Wed May 20, 2020 5:25 pm
It’s been in the garage all day today. I haven’t heard from them as of yet. I’ll give them a call tomorrow I don’t like to rush them. I did mention when I dropped it iff about all the poor wiring and the maf sensors. Hopefully I’ll know my tomorrow and of course I’ll keep the post updated.
Gareth1984
Post by Gareth1984 » Thu May 21, 2020 1:23 pm
Just out of curiosity does anyone know how much a replacement gearbox or a full rebuild is including labour.
Post by Shoppinit » Thu May 21, 2020 1:44 pm
between 2k and 10k depending on where you get it done. Obvs the 10k end is Audi.
Gareth1984
Post by Gareth1984 » Thu May 21, 2020 1:53 pm
Obviously I’d like the 2k then lol.
I rang the garage they have still not found the exact cause. But they have said there is definitely a fault in the gearbox. I’m waiting on more information from them hopefully later today. I’m just thinking the worse case scenario and expecting the big bill. Where are these places for under 3k Do you know ?
Mines Currently in D & K motors Leicester
Post by Shoppinit » Thu May 21, 2020 1:59 pm
Have a look in the FAQ. There's some info in there.
It would be nice to have some proper VAG fault codes. You should get a Vagcom. It's the first tool any RS owner should buy!
Gareth1984
Post by Gareth1984 » Fri May 22, 2020 12:09 pm
I’ve had the dreaded news it’s the gearbox. It’s burnt out and buggered parts inside. I’ve been quoted £4,600 for a full recon, but i still have the abs issue so looking over 5k total. Is there any recommendations for any places cheaper. I’ve tried Looking in the FAQs but couldn’t find anything.
Post by Shoppinit » Fri May 22, 2020 12:12 pm
What did they say exactly?
Post by Shoppinit » Fri May 22, 2020 12:14 pm
Shoppinit wrote:
Fri Apr 01, 2011 11:31 am
Known Gearbox rebuilders
£1600 gearbox rebuild all in, apparently. Awaiting feedback: http://www.autotransuk.com
JT Automatics in Erith possibly used by AMD
Chester Automatics possibly used by Unit20
Sussex Auto Transmissions, ZF UK authorized partner.
RichB888 wrote:Automatic Transmissions of Preston.. Avoid.
HPsauce
Post by HPsauce » Fri May 22, 2020 12:26 pm
I know people who will only go here: https://www.mackie-transmission.com/
srichards
Post by srichards » Fri May 22, 2020 12:36 pm
If you use a cheaper place is there any guarantee the work will last? Better to pay a bit more and have it done correctly and also have a proper decent warranty with it.
Also make sure you can pay with a credit card then you have extra protection as well.
Gareth1984
Post by Gareth1984 » Sat May 23, 2020 4:27 pm
Thanks all I’m going to be doing some shopping around. I don’t mind paying 4,600 but it’s always best to get other quotes.
They said a lot of things inside the gearbox have failed, I can’t remember exactly but when i pick it up on Tuesday i will get a list of everything and post it here.
Post by Shoppinit » Sat May 23, 2020 4:52 pm
At least get a cheapo Vagcom cable and shareware version of VCDS off ebay so we can see the *actual* VAG error codes. So much misdiagnosing happens with these cars by "professionals". Use the community to evaluate for yourself.
Users browsing this forum: asgor, Shoppinit and 82 guests
