rs6 c5 power loss and supercharging circuit leaks
Re: rs6 c5 power loss and supercharging circuit leaks
Yeah. More pipes in an RS6 than an oil refinery.
this is a gas plant
Envoyé de mon POCO F1 en utilisant Tapatalk
Hi Shopp, thanks for the follow-up! I'm very busy back to work so I haven't had the time to do much with the car, but no, I have no leak here as the actuators are working fine and I'm not loosing air. Admittedly one is reacting slightly earlier than the other but not that much, like one actuator starts moving with 0,3 bar pressure whereas the other at 0,4 bar. I'll update my thread as soon as time allows, but in short it seems more & more likely my problem comes from a faulty turbo..
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
I replace all the wastegate control hoses for ear-rings 9/11 minimum one size above will be simpler, mounting not difficult difficult to access I protect the conductive hose with sheath basalt and I I passed behind the heat-insulated sheet
Looking good!
Any progress? You been able to fix the lambda probes and overboost?
I did not try it right away but the overboost is back to her happiness, for cons I have not done the lambdas that before cata are not accessible according to a person of the forum can unveil the rear cradle and down it 5 cm the engine and passes the hands putting a jack or jack to relieve the block
Cool.
Some info here about dropping the subframe:
viewtopic.php?f=2&t=123494&p=830949#p830949
https://audisrs.com/little-project-on-t ... 16591.html
whoua he's beefy downpipe guy without laying the engine respect
shopinit you think that the fact that my 4 lambdas is short circuit I lose a little power or a degraded mode?
Yes, I think that is very probable.
I need to take time and I motivated myself to replace them I will try removing the air box to see if can not reach the cables or I connect the lambdas and control but connection already
hello hello news of my beast it was driving until a short time ago because of the heavy rain regulator of the alternator blocked defective I recommended the latter I expect it in the coming days, dismantling I saw that 'there was more than one thimble of oil in the hose of exchangers passage I suspect that that means that my dear tired turbos I have other similar opinions, my question I am looking for a hybrid upgarde kit to convert my turbos myself I searched and found only original CHRA or complete turbos but in my budget, I found this too
https://www.abm-automotive-online.com/p ... -2452.html
Users browsing this forum: ChrisA and 410 guests
