KWE vs Wagner Intercoolers
Classik
Post by Classik » Wed Dec 05, 2018 7:47 pm
A quick search on the subject led me here viewtopic.php?f=47&t=120056 and there viewtopic.php?f=2&t=127055
But except if I missed something, it seems like those KWE intercoolers are not good for the C6 platform but I didn't find first hand experiences for the C5 platform.
Definitely not my priority at the moment, but as there's currently a nice 24% discount at KWE, you would pay like 600€ for the kit (intercoolers + silicone hoses and clamps but without air ducts), which is worth considering. I would probably buy the air ducts from Wagner as they allow for the fog light to stay (not the case with the KWE air ducts).
Comments anybody?
Cheers!
benh999
Re: KWE vs Wagner Intercoolers
Post by benh999 » Wed Dec 05, 2018 7:54 pm
Have a look at Airtec,
They use the OE end tanks and weld in brand new high flow cores..
https://www.airtecmotorsport.com/produc ... r-service/
Best bit is the fitment is spot on still...
Classik
Post by Classik » Wed Dec 05, 2018 8:02 pm
Thanks for the heads-up! I've seen your recommandation on the other threads but the idea was also to gain power. Those Wagner or KWE offer almost twice the volume and larger surface compared to the OEM (even refurbished) which makes a difference.
rs4wagon
Post by rs4wagon » Wed Dec 05, 2018 8:51 pm
stock ones are good for 600bhp,you going to do more then that??
Classik
Post by Classik » Wed Dec 05, 2018 9:33 pm
Certainly not, but my understanding is that cooler air is beneficial at all engine loads: less air volume needed for the same amount of oxygen means better efficiency.
Jayjay101
Post by Jayjay101 » Wed Dec 05, 2018 11:29 pm
rs4wagon wrote:stock ones are good for 600bhp,you going to do more then that??
You sure about that?-I could be wrong but I don’t know of any car running anywhere near that power on standard coolers.They heat soak really bad for a start and they leak!
MattV8
Post by MattV8 » Thu Dec 06, 2018 1:25 pm
Yup. This is where marine turbo engines are awesome - they have water cooled intercoolers so can achieve efficiency >1 - the air going into the motor after turbocharging is lower than ambient!
...my understanding is that cooler air is beneficial at all engine loads: less air volume needed for the same amount of oxygen means better efficiency.
Classik
Post by Classik » Thu Dec 06, 2018 8:53 pm
:thumbs: You learn every day..
Sooo, KWE intercoolers for the C5 platform anyone?
rs4wagon
Post by rs4wagon » Fri Dec 07, 2018 12:25 am
friend of mine,2xgt28 650bhp stock smic so its confirmed
Post by Shoppinit » Fri Dec 07, 2018 6:56 am
I wonder if he’d get gains from bigger IC though.
///M3 E46 -- XC90 (V8, natch)
Jayjay101
Post by Jayjay101 » Fri Dec 07, 2018 10:52 am
For it to be confirmed we need to see proof! As my understanding is stock intercoolers are only good for one power run on a dyno then they suffer from heatsoak and unless they have been welded they will be leaking!
rs4wagon
Post by rs4wagon » Fri Dec 07, 2018 9:55 pm
0.9 bar 602hp 725nm
1.1 bar 643 HP 875nm
going for 800/1000 this winter
Users browsing this forum: Ajc, jolio1994, Puggie, Sammyb349, Shoppinit and 37 guests
