Front axle oil seals, ATF fluid needs to be drained?
atledreier
Post by atledreier » Sat Jun 11, 2016 9:52 pm
Was doing a left front bearing and bushings at my local Shop, and figured they could swap the oil seal on that side as well, as there's a slow drip. They claim pulling the axle will drain the box and require a full fluid swap. Is this correct?
2003 RS6 Avant, Daytona grey
2012 Toyota GT86
2014 Toyota Prius Plus 7
Re: Front axle oil seals, ATF fluid needs to be drained?
Post by Shoppinit » Sat Jun 11, 2016 11:40 pm
Depends which side. If you pull the left shaft out of the diff then you will leak diff oil into the atf IIRC. You need to drain some diff oil out first. The manual will tell you the details.
atledreier
Post by atledreier » Sun Jun 12, 2016 8:55 am
Thanks. It is the left side. Is this manual available somewhere?
2012 Toyota GT86
Users browsing this forum: No registered users and 279 guests
