power steering pump
subtacex
power steering pump
Post by subtacex » Fri Mar 13, 2015 7:00 pm
Anybody know the oem number for power steering pump...mine is a little noisy ..getting a little concerned
Thanks in advance
E28 M535i
E39 M5
IMPREZA 22B
JCviggen
Re: power steering pump
Post by JCviggen » Fri Mar 13, 2015 7:04 pm
Lots of things can cause that noise, from a loose clamp to a small leak somewhere. The noise is generally pump cavitation. Mine has been noisy to VERY noisy on cold winter starts since I got the car 4 and a half years ago. Still no sign of the pump actually giving up, and on occasion it was noisy for miles even driving in a straight line. I forget about it when spring rolls around and it's quiet again. Many fluid flushes have been done with varying degrees of improvement, never lasting long.
981 Cayman GTS Gray/Orange.
My youtube
RichB888
Post by RichB888 » Tue Dec 15, 2015 3:41 pm
sorry to jump on someone else's old post but seems relevant...
my PS pump? started making a noise recently as well, on inspection I could see a glittery look to the PS fluid. (Im assuming its the pump as the noise increases when turning the steering when stationary and goes away when not under load).
Since my cars already sat with the engine and box on the floor (gearbox rebuild) Ive just told them to go ahead and replace the PS pump as well (hardly going to make a great deal of difference to the price in the grand scheme of things!).
Any thoughts?
Post by Shoppinit » Tue Dec 15, 2015 3:56 pm
The glitter sounds like swarf. Could be pump or rack. Don't feel like changing the rack while it's all in bits, too? :)
Nobby
Post by Nobby » Wed Dec 16, 2015 10:40 am
My pump is a teeny bit noisy first thing, going slow, first gear and tight turning. I've done a few fluid changes and my fluid has a lovely green tinge to it just like the stuff straight out the bottle.
There was a chap in the US who rebuilt one for a S6 (they looked very similar), but I don't know where you'd get a rebuild kit. Also it didn't get rid of the noise.
Daytona RS6 Avant
RichB888
Post by RichB888 » Thu Dec 17, 2015 11:51 am
hmm, well ill take a hit on replacing the pump first, at least the rack (I assume!) should be easy enough to replace even once the engine and box are back in.
Post by Shoppinit » Thu Dec 17, 2015 11:56 am
Got a feeling the rack is an engine out job. Could be wrong though.
Post by bam_bam » Thu Dec 17, 2015 12:47 pm
The rack is about £400 to rebuild but it's an engine out job unless you can get around the £1500/$1500 bolt thing. I think it was a term coined by RS6.com in reference to trying to remove the center bolt with the engine is situ, I think someone did manage it, then held the bolt in question aloft and said "beholden, the $1500 bolt". Ameritards.
RichB888
Post by RichB888 » Fri Dec 18, 2015 1:50 pm
huff.... ! is there anything on this car that does require the engine to be removed first?!
Thanks for that, ill speak to them now to before its too late.
Nobby
Post by Nobby » Sat Dec 19, 2015 12:04 pm
Thought panda had her rack replaced without removing the engine.
Daytona RS6 Avant
Post by Shoppinit » Sat Dec 19, 2015 12:07 pm
Nobby wrote:Thought panda had her rack replaced without removing the engine.
Is that a euphemism?
G pat
Post by G pat » Sat Dec 19, 2015 12:30 pm
Yeah, I'm thinking saggy boobs to pert puppies.....
lswing
Post by lswing » Sat Dec 19, 2015 4:51 pm
RichB888 wrote:hmm, well ill take a hit on replacing the pump first, at least the rack (I assume!) should be easy enough to replace even once the engine and box are back in.
Hahahahaha :audibash:
You can remove without taking out the engine, difficult to get to the bolts. My mechanic did it though :notworthy:
Revo Tune + extra ME7 fueling - MTM TCU - Wagners - Koni Struts - DevilSown W/M - Michelin PSS's - Hotchkis Sways - Upgraded TC/Trans - Mugello/Black/Carbon
Nobby
Post by Nobby » Sat Dec 19, 2015 11:39 pm
Ofcourse. You should hear my one about the swarfy slush box.
Daytona RS6 Avant
RichB888
Post by RichB888 » Tue Jan 12, 2016 12:45 pm
new PS pump resolved it for me. Thankfully wasn't the rack.
