600+ hp turbos
supersi
600+ hp turbos
Post by supersi » Sun Aug 31, 2014 10:58 am
Thought id share these puppys i've just done for UNit20
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
IanH755
Re: 600+ hp turbos
Post by IanH755 » Sun Aug 31, 2014 2:35 pm
That's a lot of work and effort you've put in for something that'll never been seen again once fitted! Is there any benefits other than visual to the coatings?
I wonder who the lucky guy/gal is (Daz?)
supersi
Re: 600+ hp turbos
Post by supersi » Sun Aug 31, 2014 10:55 pm
In the scheme of things that it takes to produce upgrade Motorsport turbochargers at this standard. It's just like the icing on the cake :thumbs:
Offers no performance gain just really done to finish of. To be honest coating of the parts is very little effort, only thing I can think off is coating will help hold off corrosion.
Re: 600+ hp turbos
Post by Shoppinit » Mon Sep 01, 2014 7:50 am
Are these the same as the ones Amanda has?
S4Player
Re: 600+ hp turbos
Post by S4Player » Mon Sep 01, 2014 9:57 am
Amanda has LOBA they are completely different
Weiß-sechs
Re: 600+ hp turbos
Post by Weiß-sechs » Mon Sep 01, 2014 3:08 pm
Look great, very much doubt you'll get the full 650 bhp with them though; fannymolds will put paid to that
supersi
Re: 600+ hp turbos
Post by supersi » Mon Sep 01, 2014 3:24 pm
Hi Shoppint,
No are not same as Amanda's but really was many years ago so cant remember exact spec and not same company as S4Player says.
Spec of these TTE units are, Genuine BW RS6 housings, K04 BW clipped exhaust turbines, BW 2283 billet compressors, CNC reprofiled compressor housings to a optimum gap, ported boost discharge pipes, ported exhaust throat before turbine, reinforced/uprated actuators, motorsport bearing system, Balanced at far higher standard over stock in multiple planes.
Weiß-sechs,
Yes really this car will not be tuned for power and as you say stock manis are so so restrictive (i've cut apart and inspected), more these units was chosen by unit20 for efficiency i.e. Good power/airmass and response at lower turbo shaft rpm.
Weiß-sechs
Re: 600+ hp turbos
Post by Weiß-sechs » Mon Sep 01, 2014 3:38 pm
Just out of interest what are the actuators rated at? I've got 1bar on my hybrids which is a bit OTT I thought, 0.7 to 0.8 bar would be more sensible
mavada
Re: 600+ hp turbos
Post by mavada » Mon Sep 01, 2014 6:37 pm
...why isnt there a package, those turbos with upgraded gearbox...?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
seaneb
Re: 600+ hp turbos
Post by seaneb » Mon Sep 01, 2014 8:34 pm
And tubular manifolds
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
Weiß-sechs
Re: 600+ hp turbos
Post by Weiß-sechs » Mon Sep 01, 2014 8:57 pm
coz you'd need a manual conversion to go.....got a spare £8k+ ? Where's the Baminator when you need the voice of reason?
longman h
Re: 600+ hp turbos
Post by longman h » Wed Sep 03, 2014 7:03 am
Surely with uprated clutch packs and a torque converter than can take it, it would be ok non?
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Re: 600+ hp turbos
Post by Shoppinit » Wed Sep 03, 2014 7:54 am
The problem is one of physical space.
Re: 600+ hp turbos
Post by bam_bam » Wed Sep 03, 2014 1:15 pm
Shoppinit wrote:The problem is one of physical space.
Why, these are RS6 housings, right?
These will need an enlarged intake feed to flow rated power... but Grizz knows that. In fact there'd be a whole bunch of supporting mods to get these puppies barking with a bite to match. Can only assume these will be added to a recently repainted Daytona avant, given that Daz doesn't seem to cut corners, this could get tasty.
@Si - why only a coating on the cold-side?
Re: 600+ hp turbos
Post by Shoppinit » Wed Sep 03, 2014 1:19 pm
Got confused. Thought we were talking about putting bigger snails on.
Users browsing this forum: No registered users and 176 guests
