Brakeupgrade C6 discs? what do i need?
Deckedm
Post by Deckedm » Sun Aug 18, 2013 5:15 pm
Hi people, ive got some C6 RS6 discs laying around 390x36 and id like to use them on the RS6 C4.
What is needed to use these discs with the 8 pots RS calipers? i guess well be needing a custom made bracket?
Has anyone done this before???
thankyou
Daveperc
Re: Brakeupgrade C6 discs? what do i need?
Post by Daveperc » Sun Aug 18, 2013 7:37 pm
Hi there
Assuming that the C4 was meant to say C5, then your best bet is to contact Grizz at Unit 20 who can supply all the parts you need to do this IIRC
R8GXR
Post by R8GXR » Sun Aug 18, 2013 9:02 pm
When I enquired they were not doing parts for this now. TBH, my totally refurbed setup with plus discs, braided lines and race pads seem more than up to the job on the road. Off to the ring Sat so will see what their like there.
Daveperc
Post by Daveperc » Sun Aug 18, 2013 9:36 pm
I think you are probably right that he's not still doing it (I had heard rumours), but he might be able to point you to someone who has made the brackets and spacers before.
Otherwise I dare say Bam or one of the others who has gone down the big brake route may be able to point you in the right direction - do a bit of a search and you may get some clues.
Mr V10
Post by Mr V10 » Mon Aug 19, 2013 12:14 am
Bam has the full kit, so swapped his 8 pots for the C6 6 pots. I was told it was pointless putting the C6 390mm discs on C5 8 pots as you don't get full pad sweep, amongst other things.
Post by bam_bam » Mon Aug 19, 2013 4:50 pm
You'll need a 6.7mm spacer and a custom center ring. That's it. Well, maybe longer bolts.
The C6 discs have a larger bore than the C5, without the center ring (spigot) the wheel will only rely on wheel bolts to centre the C6 disc. Also, you don't want the weight of the car on the wheel bolt, you want it on the hub.
Honestly, using the C6 discs isn't the best solution and doing it as above still isn't that safe. You've been warned.
gingertoss
Post by gingertoss » Mon Aug 19, 2013 5:34 pm
That is what I have, c6 discs with c5 calipers. Centre ring and the spacer for the caliper. I agree with Bam it isn't a good solution.
I having sitting in a box c6 calipers and pads, which I will fit once A. My current discs are worn out and B. I get around to ordering the discs that actually fit.
2003 RS6 Avant, non res Miltek, 3" catless dps, wagners, MRC air filters, 044 fuel pump, MRC custom remap, TCU remap, 566ps, 812nm, pss9 coilovers, hotchkis rollbars, Recaro CSs, 390mm front discs, hi-spec 4 pot rear calipers.
ctsui35
Post by ctsui35 » Mon Aug 19, 2013 10:24 pm
Where can you buy the center ring from?
Does the car squirm when braking hard even with the center ring?
Deckedm
Post by Deckedm » Mon Aug 19, 2013 11:34 pm
Ive send some pms, send someone a email..
Now i need someone who can get/make me the rings and the spacer for the calipers to fit the 390s...
someone?
Post by chunky79 » Tue Aug 20, 2013 6:42 am
Deckedm wrote:
someone?
Is that meant to be someone or Simone? I haven't ever met anyone called someone, someone else yes, but not someone.
Have you spoke to Grizz?
Post by bam_bam » Tue Aug 20, 2013 9:18 am
ctsui35 wrote:Does the car squirm when braking hard even with the center ring?
WTF? Are you on DRC by any chance?
Deckedm
Post by Deckedm » Tue Aug 20, 2013 9:25 am
Rhian, from unit 20 told me they dont do these kits anymore, i just asked if could source the adapters from them.. but no reply.
the Rings are doable for me.. but i need an adapter for the calipers...
Hmm... ive got the c6 discs brandnew so i really like to get them fitted...
sweegie
Post by sweegie » Tue Aug 20, 2013 11:55 am
Sell the C6 disks and get a Loba / AP rotor & bell kit? This would be a miles better solution in my opinion, and one that bolts straight on.
Recycling dinosaurs for fun
Post by bam_bam » Tue Aug 20, 2013 12:33 pm
sweegie wrote:Sell the C6 disks and get a Loba / AP rotor & bell kit? This would be a miles better solution in my opinion, and one that bolts straight on.
Requires new pads, which are expensive... not to mention the price of the Loba discs! But yeah, better soltion.
Deckedm
Post by Deckedm » Tue Aug 20, 2013 11:56 pm
The car is mainly used for grocery getting, no fastroading since the wife is driving it mostly... and its mainly for aestethic reasons i want these fitted... i cant be arsed to spend 3k on another brakekit for getting groceries only ...
Martin is away on holiday.. so i hope he can get back to me when hes back..
Users browsing this forum: No registered users and 266 guests
