Faulty oil sencer
Faulty oil sencer
Has anyone had this happen?? It flashed up on a drive to London last night, is this easy to fix,? Is it accessible,? How much,?? It's the oil can symbol with the word 'min' .,,! Anyone help??
RE: Faulty oil sencer
Are you sure it's a faulty sensor? What flashed up?
Did you check the oil level? Could it be oil pressure?
Re: RE: Faulty oil sencer
Oil is perfect., oil pressure is perfect too, so it is the oil sensorShoppinit wrote:Are you sure it's a faulty sensor? What flashed up?
RE: Re: RE: Faulty oil sencer
Just 3 bolts to undo and it will slide down out of the sump. Don't forget to drain the oil first
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 153 guests
