all lights on dash for gearbox
suly
Post by suly » Wed Jan 12, 2011 7:33 pm
when put in D all the dash P R N D S light up and doesnt seem to change gear its needs revving up and then bangs into gear and doesnt seem to go right seem perfect in reverse tho ??? any one expeirenced the same or have any usefull info ??
RS6Steve
RE: all lights on dash for gearbox
Post by RS6Steve » Wed Jan 12, 2011 8:56 pm
Torque converter / Gearbox
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
amanda1
Re: RE: all lights on dash for gearbox
Post by amanda1 » Wed Jan 12, 2011 9:12 pm
RS6Steve wrote:Torque converter / Gearbox
Agreed................hope you have some sort of warrenty cover on the car :roll:
gorwanvfr
Post by gorwanvfr » Wed Jan 12, 2011 10:10 pm
Get a vag com on it and see what the error code is. Could be the F125 switch. Have a read of this http://www.audipages.com/Tech_Articles/ ... place.html
BigMo
Post by BigMo » Wed Jan 12, 2011 10:27 pm
I had the same. Found that by switching the car off an then back on seemed to cure it but the TC was shagged!
RS6 (MRC'd with econodrive) is not just for Xmas
Toyota Aygo Platinum for minimising carbon footprint.
mavada
Post by mavada » Wed Jan 12, 2011 10:58 pm
i had the same issue, was getting worse when it was getting colder outside, replaced the f125 switch and now works great...
Not that easy to get it out, some parts has to be removed first.
The link to the audipages site is about replacing the f125 dwitch on a A8, so that is something different...
suly
Post by suly » Wed Jan 12, 2011 11:31 pm
ive had it on vag and its bought out code
GEAR RATIO MONITORING INCORRECT 17114 P0730
cleared code but soon as i start it it comes back
could it be anything to do with control unit ??
suly
Post by suly » Wed Jan 12, 2011 11:54 pm
thanks to all for your suggestions :thumbs:
S2tuner
Trader (Expired)
Post by S2tuner » Thu Jan 13, 2011 4:26 am
suly wrote:ive had it on vag and its bought out code
This fault code seems to be from the engine control unit, not from the tiptronic control unit. do you have access to a VAG-Com?
Post by Shoppinit » Thu Jan 13, 2011 9:27 am
Could be caused by a seriously slipping brake in the box, too. Given the other symptoms (slipping and banging) I would lean towards a worn out box. But, definitely try to change the ATF first. Could be low which would give similar symptoms. Could be a sticky solenoid. Hope for best, plan for the worst.
@Mihnea, I am ready for more potatoes :)
jd_hants
Post by jd_hants » Fri Jan 14, 2011 1:43 pm
I had something very similar - cant remember the fault codes though - simply turned out to be low oil level in gearbox due to an oil hose coming lose and leaking. Replaced oil and has been fine (touch wood) - I was very lucky!!!
SteveCuz
Post by SteveCuz » Fri Jan 14, 2011 3:25 pm
I had all the light come on 6 months after buying. I went to Audi and they changed the oil. I was convinced after reading this forum my gearbox was gone but 2 1/2 years later and everything has been sweet. Got Grizz to change the oil for a second time 12 months after the first as a precaution.
Steve
2011 Audi RS3 Daytona Grey | 2003 Audi RS6 Avant Ebony Black
Users browsing this forum: No registered users and 156 guests
