drivers door not closing
Hope there is a simple fix to this opened up the car this morning and it has been very cold overnight ( car completely frozen) when i went to shut the driers door it wouldn't close. The latch in side the door didn't appear to be catching. is this anyone else has come across and is there a quick fix?
RE: drivers door not closing
quick fix is wait for lock to thaw out ,moisture has got into the lock and frozen , worse case scenario , it wont even open, same with windows not winding down etc
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
its just unusual that it was only the drivers door! is there anything i can do to stop it happening again?
parking it in a less exposed direction might help ?
I too had this but with the passenger side, But it was not frozen, does it every now and again for some reason, simply doesnt catch.
My passenger door does it sometimes. It appears that the more you slam it, the less likely it is to close properly. Just pushing it gently closed works fine.
Lubricate the mechanism in the short run.
If eventually you're out of patience a new door latch is on the cards!.
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
volkscraft
Users browsing this forum: Google [Bot] and 147 guests
