Soft Shock?
Glencoe2
Soft Shock?
Post by Glencoe2 » Fri Aug 27, 2010 11:41 am
OK - just got my 03 RS6 back from my local garage where my very good "local" mechanic has diagnosed a soft (very) shock on the back drivers side.
He mad some enquiries for me to a technical line at VAG and they said the whole DRC needs changing...! I have read a few posts here and realise its a common problem.
What is the best course of action - i gave up on Audi dealerships a few years ago after the Extended warranty lapsed and so far my local man has been excellent - he managed to balance and track the car and get rid of a vibration that two Audi Dealers had tried and failed to diagnose / fix.
Am i going back to Docklands Audi? Did i read a while ago that cars like mine might get a post warranty fix (60k)???
thanks for anyones thoughts
Rupert
Re: Soft Shock?
Post by Rupert » Fri Aug 27, 2010 11:50 am
Glencoe2 wrote:Am i going back to Docklands Audi? Did i read a while ago that cars like mine might get a post warranty fix (60k)???
No. It's up to 6 years old with full Audi service history.
Just put coilovers on, KWV3s, Bilstein, or H&R. Add anti-roll bars for flatter cornering. Less than £2k for the lot and no more worries.
A soft shock at the back will be dangerous, you have probably already noticed the rear of the car side-stepping when going over ridges on motorways or around corners?
AMD near lakeside did my KWV3s and H&R ARBs. It transformed the car.
RS6Steve
RE: Re: Soft Shock?
Post by RS6Steve » Fri Aug 27, 2010 12:39 pm
Soft shock, sounds like knackered DRC.
Just replace the lot as per Rupert's advice unless you want to take the risk with DRC!!!
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
morginator
Post by morginator » Fri Aug 27, 2010 2:04 pm
Audi has an extended warranty for the DRC for up to 100,000 miles and up to 6 years ols with full main deaqler service history. Might not be much help if you have used 'your own man' Audi replaced mine with the new improved DRC and I found it fine no problems so far. Its been in a year now.
Glencoe2
Post by Glencoe2 » Fri Aug 27, 2010 7:16 pm
thanks all - i have taken the plunge and booked with AMD.
Im afraid after they warranty lapsed (i advised them of a new address and they still sent the renewal to my old one - still fault I suppose), i dont want to give the stealers any more money.
AMD advise me i that unless the anti roll bars are shot they can still use them - is this a good idea?
Rupert
Post by Rupert » Fri Aug 27, 2010 8:51 pm
Yes, you can keep the original ARBs, but the H&R ones are beefier and adjustable, so you can set the oversteer/understeer balance easily. Beefier ARBs will result in less body roll on corners, and they aren't that expensive to buy & fit anyway.
I nearly forgot: change the suspension top mounts at the same time. AMD will know what to do, the top mounts are cheap.
Post by Shoppinit » Sat Aug 28, 2010 10:43 am
I use Bilstein PSS9 on the original ARBs. Works a charm.
Users browsing this forum: No registered users and 249 guests
