Gearbox oil change, only 6.5 litres??
Serviced my car over the past couple of days and did a gearbox oil change as per the instructions in the ZF manual and on audipages etc. When I drained the fluid I collected it all in a bucket and to my surprise it was just over 6 litres drained in total (this was over a 48hr period). I refilled the gearbox today with fresh fluid and it took the exact same amount as I had drained. I used VAGCOM to monitor the fluid temp up to 35C and followed the ZF refilling instructions to the letter. Those who have done this will know it is a difficult job, especially doing it single handed, but I am pretty confident that it will take no more than 6.5 litres. I had initially assumed that my oil level was low due to draining only 6 litres - I think I was expecting closer to 8. Can anyone tell me if this appears to be normal?
2003 RS6 MTM 568
RE: Gearbox oil change, only 6.5 litres??
hey bud, i dont know how much the gearbox takes, but last year i had to reckon the gearbox because the guys at audi didnt put the correct amount of oil in and the clutches burnt out.
almost $4000
so rather make sure
almost $4000
so rather make sure
I'm surprisesd it took that much. Normally you can only get about 5 out. A lot stays in the TC. you just can't get it all out in one go without removing the whole box. Yuo could do it a couple of times to get 90% of the fluid...
I'm assuming also that the car was level, you did the level with the engine running and you ran through all the gears?
Re: RE: Gearbox oil change, only 6.5 litres??
Yep, exactly as the ZF manual describes. The job was done on a car lift so the car was perfectly level. I am happy with the result, just was not sure about how much I should have expected to have seen drain.Shoppinit wrote:I'm assuming also that the car was level, you did the level with the engine running and you ran through all the gears?
2003 RS6 MTM 568
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 267 guests
