DRC
red_jdm
DRC
Post by red_jdm » Fri Jun 25, 2010 6:03 am
Hi guys...last owner of the car just replaced the DRC couple months ago. I would like to lower the car now. How? Should I just change the springs? or I should go for PSS9 or even KW V3?
RE: DRC
Post by Shoppinit » Fri Jun 25, 2010 2:36 pm
Sandbags is the cheapest option. 1.99 each at B&Q :thumbs:
Seriously though, DRC is a bag of <beep>, and putting shorter spring on will just hasten your trip into the hedge. I would recommend PSS9s, but then I would.
TIMSRS
Post by TIMSRS » Fri Jun 25, 2010 7:09 pm
PSS9 kit with uprated anti roll bars. A better kit suited to the RS6 due to it's weight.
Worked a treat on mine + you can lower it as much as you like.
Daveperc
Post by Daveperc » Fri Jun 25, 2010 7:13 pm
Audi did a lower kit for the Plus - check part numbers etc with a friendly dealer (or ask on here).
DRC is fine if in good working order - it used not to be relieable but the recent v3 is much better on that front. Coilies are fine if you want a harder flatter ride, but you sacrifice ride quality on our rough roads.
Why do you want to lower the car - aesthetics or handling??
Users browsing this forum: No registered users and 98 guests
