Well it wouldn't be rubbing it in if he only single posted.chunky79 wrote:So why rub it in and post twice?IGO300 wrote:I had same problem recently.
Turned out to be water pump.
Cost approx $1500 aust incl labour.
Sorry for bad news
Coolant level warning light....
Re: RE: Re: RE: Coolant level warning light....
+1 on this side of the ditch...I had very similar symptoms, and it was the auxiliary coolant pump (that kicks in after the engine is shut down and cycles coolant to avoid hotspots forming from the turbos) that was leaking (relatively common in the Audi V config engines I understand). Another Audi special of a part that costs a few bucks needing a day or more of labour to deal withIGO300 wrote:I had same problem recently.
Sorry for bad news
RE: Re: RE: Re: RE: Coolant level warning light....
Thanx guys - i like the sound of the auxiliary pump - it would be far less costly than a block / head issue, and the engine runs perfectly so it sounds about right.
Am still unable to see the leaking coolant, and also not sure which route to go down when it comes to getting it fixed, - audi or independent.
Re: RE: Re: RE: Re: RE: Coolant level warning light....
Like I said before, put the car up in the air and look at where the transmission mates to the back of the engine. If you see coolant all crusted up between the two its the pump. Mine did the same thing, made coolant disappear like magic, never a trace thanks to the TC spinning and throwing the fluid everywhere you couldnt see it.55marcuss wrote:Thanx guys - i like the sound of the auxiliary pump - it would be far less costly than a block / head issue, and the engine runs perfectly so it sounds about right.
Re: Coolant level warning light....
Ive just had a warning and the level is a little low... Am I ok to top up with normal water or do I need a mix of some sort? Cheers in advance.
B7 RS4 - 07 Phantom, Silver leather, 59k. Current
B5 RS4 - 01 Avus, B7 Brake kit, Miltek cat back, Sroof, leather, optics. 66k. Current
B8 RS4 - Sepang, BO, Roof, Sports Sold
C5 RS6 + # 296 Ebony black, full optics, titans, carbon and natural leather - sold and missed
B7 RS4 Avant Daytona Pearl, black optics, SS+, buckets, privacy. Sold
B5 RS4 - MRC 420. Gone but not forgotten.
It should be a sealed system, so best check why the level is dropping.MEV wrote:Ive just had a warning and the level is a little low... Am I ok to top up with normal water or do I need a mix of some sort? Cheers in advance.
If you do need to top up, normal tap water is fine as long as its a small amount. Add antifreeze to the mix if you're talking litres....
Recycling dinosaurs for fun
Yep - just top up with water, and then check antifreeze concentration in the autumn before the cold weather comes in.
Dave
Dave
Gratis!
Its been a while...
Just got back from the dealership!
To their credit they have furnished me with very well equiped and new A6 3L heads up display, etc etc for the weekend and with a full apology and intention of sorting this issue and to go over all the work and again and double check. We will see how far this goes.. I gave a good rant but what do you think I can push for realistically? The missus wants me to push for inconvience and mileage compensation etc but I dont want to take the p*ss.
It's a difficult one as your main aim is to get the car back in full working order. Clearly they haven't completed the QA check's once the work was originally completed. I would expect the dealer to now resolve the problem for you at no cost and give you assurance that they've completed a full QA check by the service manager with a signed document stating what they done. Pushing for much more than that and your going to get their back's up, you never know when you may need them for something else in the future.
yep cheers
thats what im thinking although I have suggested that the monkey
that worked on my car in the first instance be sent to BMW for a month! I also said that I didnt want them to do any other additional work as Im taking the car to Camberly for a check next week as my confidence in them had gone South. The look on thier faces, other customers, sales team and coffee girls was a picture. I think at that stage I should have thought about offering on a new car!
Useless monkeys. Your mum says "if you wanted the job doing badly you would have done it yourself". Don't know what she means.
Why the hell did they take the front of the car off to change the alternator? When i did mine a few weeks back the only pipes i removed were the oil pipes from the filter housing no need to remove front end.
Users browsing this forum: No registered users and 132 guests
