intercoolers
intercoolers
Ok, I bought a pair of intercoolers of ebay. i think they leak. F@@king car is costing me a fortune, i am ready to pull the plug on ownership.
£6000.00 in three years excluding fuel!!
Should they hold water if i fill them??
what is the concept to a intercooler??
RE: intercoolers
Never heard of a water test, but then most are tested in situ with air pressure. Can't see what harm it would do to water test them. As long as you dry them out before butting them on the car.
They are supposed to be gas tight so if they leak water then there must be some pretty big holes in them. Small holes that let gas escape may not let water through, though I think in this gas the holes will be too small to affect performance.
- Golffather
RE: intercoolers
get em pressure tested by mrc at time of fitting if poss
kaisersolsay
RE: intercoolers
I was bidding on these intercoolers also just to have spare in the garage. Glad I didnt touch them. If you paid by Pay Pal get your money back mate.
RE: intercoolers
Easy to do a pressure test .. If they leak get them cleaned and resealed.....
Unit 20
0151 3366888
0151 3366888
RE: intercoolers
Well, do they leak or not?
Yeah they leak!!!
Im dissapointed with the youth i bought them off, I reckon he knew they were leaking.
What i think im gonna do is take grizz's advice.
diy job. get down to my mates garage. follow the thread from RS6.com on removing i/c's and repairing them (great thread!!) fit these when repaired, clean the ones up that on the car and sell them on fixed.
Anyone suggest a good resin??
Do you think i will be able to get rid of the repaired i/c's?
Isn't there another aftermarket solution other than the wagners?
just so you know that repair he did failed, 3 times I believe.GregRS6 wrote:Yeah they leak!!!![]()
RS6-4dr911
- 1st Gear
Anyone got a set of these Apikol jobbies? What kind of performance gain should you expect?
I would imagine a tricky weld repair to do...... gouge out, prep, preheat, right weld material with same Vc as the parent alloy, controlled cooling.....not for the inexperienced.
Epoxy is an option but not sure on the longevity of it in the cyclic heat/cooling stress regime. Devcon is well respected but I have never used it for this type of stuff http://www.devcon.com/products/products ... %20%28F%29
or their Ti version resists 350 degrees F.
Why dont you ping the guy on RS6.com to see if his repair is still air tight....
I would be interested in comparing logs of a healthy car with one with leaky intercoolers. My thinking is that leaky IC would take longer to pressurise. Although the car would be running richer than normal.
Users browsing this forum: No registered users and 113 guests
