philroach(H&R's) : Front 642mm, Rear 654mm
Johnny11 (DRC) is : Front 662mm, Rear 680mm
amulet-s6 (Stasis CO) Front 668mm, Rear 678mm 265/35/19
jd hants ( DRC ) :Front 672mm , rear 688mm
moocher (H&R's ) :front 640mm , rear 630mm
RIDE HEIGHTS ?
philroach(H&R's) : Front 654mm, Rear 642mm
sorry , had mine wrong way round !!
still not sure if front or rear should be higher tho ?
buzzard666uk
Cornishmoocher
- Top Gear
probably, in the general run of things, you want a bit more travel in the rear to allow for loading.
As i said, the only reason mine were set up like that was to get he over the erfin gurt pot holes in our lane and the crap roads here, just gives me a bit more clearance clarence.....
It's all Bollox.
am tempted to raise the rear about 15 / 20mm to improve balance , is it diy , or special tools etc ?
Users browsing this forum: No registered users and 554 guests
