RS6 Discs and Pads
reprs
RS6 Discs and Pads
Post by reprs » Wed Sep 30, 2009 1:30 pm
Can anyone point me in a good direction for replacement front discs and pads in Bucks/Berks. Have been quoted between £860-£960. Does that sound about right?
Ramone
RE: RS6 Discs and Pads
Post by Ramone » Wed Sep 30, 2009 1:36 pm
no - it sounds shocking - I wrote a post on this issue called £400 or £450 a while back - check it out
Daveperc
Post by Daveperc » Wed Sep 30, 2009 1:42 pm
Probably your best bet is to give MRC (Banbury) a call - they'll doubtless do a good price. Not sure if they are offering the C6 upgrade yet, but they may be (any news Doug??)
Otherwise parts from DSGWagen (Doncaster) seems to be the cheapest for OEM in most people's experience - they are on ebay.
Otherwise ring Rob at Camberley Audi - he can usually offer a good deal! (Oh and you get to see his FIERCE 500 as well!!)
reprs
Post by reprs » Wed Sep 30, 2009 2:06 pm
Thanks, sorry should have added that included fitting. Is it still shocking?
Post by Shoppinit » Wed Sep 30, 2009 6:09 pm
Try Virdee, too.
mattler
Post by mattler » Fri Oct 02, 2009 12:40 am
Are the Phaeton disks a straight swap??
Cornishmoocher
Post by Cornishmoocher » Fri Oct 02, 2009 7:27 am
^^^^^ nope.
It's all Bollox.
Post by Shoppinit » Fri Oct 02, 2009 8:01 am
So what needs to be done for them to fit? Because DavidK's got them on.
Daveperc
Post by Daveperc » Fri Oct 02, 2009 9:27 am
The answer's on an earlier post - needs a small shim/space because the offset isn't quite the same.
Post by Shoppinit » Fri Oct 02, 2009 9:39 am
offset on the caliper? Or the disk?
Post by HYFR » Fri Oct 02, 2009 10:42 am
thats the rears thou....i think the fronts are no cheaper an so best to go OEM
jd_hants
Post by jd_hants » Fri Oct 02, 2009 11:05 am
anyone know the price of a pair of drilled OEM fronts with pads?
