Where to buy longer grille after removing fog lights ?
I'm looking for longer air guide grille after removing the fog lights.
Where could I buy the parts like on the pictures bellow ?
RE: Where to buy longer grille after removing fog lights ?
give MRC a call they supplied me with mine
RS6 Avant, black with black wheels, front S6 led lights, rear smoked Led lights, miltek non-res, miltek cat by-pass down pipes, ITG air filters, H&R kit with Arb's, MRC stage 2
e-mailed Lucas @ MRC. I will see what will be the response.
Why would you do a thing like that?
Not a dig, just curious
When you take the fog lights + plastic around it the intake temperature drops down 10-15 degrees Celsius.
I came to this after analysis of VAG-COM and the intake temperatures together with engine ignition <beep>. The ECU is not moving back the ignition that much now. The tests where conducted in several runs 0-200km/h or 60-160km/h.
RS6 Silver Avant, ABT chip, Phaeton brake ducts mod, ECS stainless steel brake lines, engine cooling mod. More to come
www.rs6club.pl
So basically more performance or throttle response. Intersting! May do this myself.
Matty
Matty
the air that gets to the cylinders has certain temperature, the lower the temperature the better engine runs giving more power
the air on standard RS6 + chip is 40 up to 65 degrees Celsius
so taking out the fog lights + the plastic lest more air to the intercoolers thus cooling them down more
Take a look at Sportec RS600 car and the parts that come with Sportec Intercoolers
The easiest thing is to test that with VAG-COM and wath the intake temps.
www.rs6club.pl
I am interested in these as well..
No luck at MRC. Lucas did not reply
I'm looking still ...
www.rs6club.pl
Users browsing this forum: Bing [Bot] and 190 guests
