Unfortunately or fortunately the only way the gearbox ECU can only be done via the classical chip tuning way, which is chip desoldered, read, programmed with a modified program and soldered back on the ECU. Just as well it's done this way, so "OBD2 only" tuners can't do anything about any tiptronic at all.SteveG wrote:S2tuner wrote:No one in the world can flash a tiptronic ECU through OBD2 as far as I'm aware, I don't even think the ECU supports it...SteveG wrote:Does anyone know the answer to this question ?:
If you have your gearbox remapped by someone like MRC, then does the gearbox ecu have to be taken out and re-soldered back on ? or is the process the same as simply plugging into the main ECU port? (no removal and then soldering involved)
Steve G
As for how visible it is, I can solder so no one can see that the chip has been soldered before or not.
I didn't mean remapping the gearbox via the OBD2 port, I was asking if it was a similar process (via a similar plug in cable method)
gearbox remap question
Re: gearbox remap question
RE: Re: gearbox remap question
Just out of interest.......
How much does the gearbox remapping cost on top of the Stage 2 + engine remap if I were to have the whole lot done at the same time ?
03 Mugello Blue Avant, Silver Leather, Carbon Fibre, Alcantara Headlining, MFSW, Electric folding Mirrors. H&R Coilovers, Hotchkis ARB's, Res Miltek, APR R1's, ITG Filters, RNS-E, OEM Bluetooth, Digital Freeview and Headrest Monitors, Aero Wipers, Rear Aero Wiper and R/H parking Mod, Rear Fog mod, Valentine 1.
RE: Re: RE: Re: gearbox remap question
Quick question from a Newbie! What is the Stage 2 Gearbox map? Does that mean you also do a Stage 1, or that this is your second or evolved map if you see what i mean!
Re: RE: Re: RE: Re: gearbox remap question
Dammit Janet I know I'm newish but I had hoped for a bigger clue than that!!355marcus wrote:Quick question from a Newbie! What is the Stage 2 Gearbox map? Does that mean you also do a Stage 1, or that this is your second or evolved map if you see what i mean!
RE: Re: RE: Re: RE: Re: gearbox remap question
Sorry Marcus, I missed your question... for tiptronic cars, the stage 1 simply involves raising the torque limiter so the gearbox doesn't hunt between 5th/4th gears, it is mandatory with a remap on any tiptronic vehicle. The stage 2 is more evolved with improved shift patterns, higher shift points, and allowing you to go into 5th gear at 30 mph.
hope this helps,
Mihnea
hope this helps,
Mihnea
Users browsing this forum: No registered users and 302 guests
