Will the 19" Wheels fit after H&R coil over install
lfd
Post by lfd » Thu Jan 22, 2009 10:55 pm
I’ve been lurking around here for a while and now I am coming out of the closet =)
So here are a couple of questions:
I believe my DRC is shot , and planning on installing a H&R set. Iw got 19â€
Cornishmoocher
RE: Will the 19" Wheels fit after H&R coil over ins
Post by Cornishmoocher » Fri Jan 23, 2009 3:20 am
hello and Welcome!
Yes to all of the above.
19" and H&Rs is no problem.
I had mine set for a while at 75mm. The tops of the tyres were up inside the arches, and it ran no problem- and i live on a farm!
sounds like the box is knackerd.
yes its very expensive- sorry! Mine was £8000 to replce by Audi.
It's all Bollox.
paulm846
Post by paulm846 » Fri Jan 23, 2009 9:55 am
hey mate, i have billsteins all round and you can keep stock height with them, my tc has just gone and its around 5,500 quid
c6 rs6
Spacecowboy
Post by Spacecowboy » Fri Jan 23, 2009 12:14 pm
its no problem
Best Regards
Daniel
rs4 v8 - h&r - 20"wheels - slow but looks awesome
http://www.rs-quattro.de
lfd
Re: RE: Will the 19" Wheels fit after H&R coil over
Post by lfd » Fri Jan 23, 2009 9:44 pm
paulmoss wrote:hey mate, i have billsteins all round and you can keep stock height with them, my tc has just gone and its around 5,500 quid
Thanks for all answers.
Ill probably go with the H&R´s
How did you know you TC were out of order?
grizz
RE: Re: RE: Will the 19" Wheels fit after H&R coil
Post by grizz » Fri Jan 23, 2009 10:57 pm
H & R's work well , The box is expensive . The last one i did was just under £5k ( That's a new Audi part)
Unit 20
0151 3366888
Hartge
Post by Hartge » Sat Jan 24, 2009 1:15 am
Just had mine done two weeks ago under warranty at Audi Worcester and asked for a photocopy of the invoice that they sent to the warranty company for my records.
Gearbox £2550.61+vat
Misc bits (Oil, gaskets etc..) £110.62+vat
Labour £2404.50+vat
So in all, if I didnt have the warranty I would of had a bill for just over £5,800.
ledzep
Post by ledzep » Wed Feb 04, 2009 11:32 pm
I have H&R's on mine sitting at 70mm. Although I don't get any rub or grounding I think it'll look better a bit higher. I'll be changing it soon.
I also had what appeared to be TC problems (snatching, slipping, vicious kick downs) which started in the cold weather. A gear box service has sorted it out. It now functions perfectly. I doubt most people will be as lucky but it cost £300 which is worth trying before you spend £5.5k ;)
MoRS6+
Re: RE: Re: RE: Will the 19" Wheels fit after H&R c
Post by MoRS6+ » Wed Feb 04, 2009 11:39 pm
ledzep wrote:I have H&R's on mine sitting at 70mm. Although I don't get any rub or grounding I think it'll look better a bit higher. I'll be changing it soon.
Where did you get the gearbox service done ledzep?
ledzep
RE: Re: RE: Re: RE: Will the 19" Wheels fit after H&
Post by ledzep » Wed Feb 04, 2009 11:41 pm
MRC
It was supposed to have been done in 2007 by Slough Audi but it looks like they hadn't done it properly as the sump was lose and the fluid was pretty dark.
SteveCuz
Post by SteveCuz » Thu Feb 05, 2009 11:41 am
Yes Gearbox service is the way to go. Sorted me out.
Steve
2011 Audi RS3 Daytona Grey | 2003 Audi RS6 Avant Ebony Black
grizz
Post by grizz » Thu Feb 05, 2009 1:02 pm
I recommend a gear box service every 50k ..
Unit 20
0151 3366888
Users browsing this forum: Majestic-12 [Bot] and 197 guests
