LPG
pistonart
Post by pistonart » Wed Feb 06, 2008 11:33 pm
I had Motec 800 and ADL, fantastic kit.
Phil Price was running his car on LPG and the motec would inject the petrol like NOS to give it a boost like a turbo would at given range.
swilkins
Post by swilkins » Thu Feb 07, 2008 10:30 am
starting to have second thoughts now...! My biggest concern was whether the twin turbo engine would need too much "injected" and overwhelm the system. I am going to do a bit more research before making up my mind. The problem is I do 30-40k a year, the RS6 is my daily driver and so the fuel is a considerable cost...
Will let you know if I find out anything, - Mattysupra, did your friend have it fitted to an RS6 and was it covered by any sort of warranty / insurance - I suspect not but you never know.
stc1973
Post by stc1973 » Thu Feb 07, 2008 7:16 pm
I run LPG on my daily drive, a 4ltr Jeep with no issues, but I have a friend who runs LPG on his SL600 and has issues. The LPG injectors can't get enough fuel into the cylinders when he boots it and the system switches back to petrol. IMHO, I would save the 2.5K and buy a diesel run around, that way you'll appreciate the beast more when you get to drive it at weekends...and you won't mind leaning on the loud pedal a bit more :rocker:
mattysupra
Post by mattysupra » Fri Feb 08, 2008 7:06 pm
swilkins wrote:starting to have second thoughts now...! My biggest concern was whether the twin turbo engine would need too much "injected" and overwhelm the system. I am going to do a bit more research before making up my mind. The problem is I do 30-40k a year, the RS6 is my daily driver and so the fuel is a considerable cost...
No it was on a toyota supra. Still a 3 litre twin turbo engine but after his little explosion it was taken off and not re-fitted.
swilkins
Post by swilkins » Sat Feb 09, 2008 9:10 pm
well chaps, I have cancelled the order for now. using the wifes A3 for long journeys in future (unless theres some twisties and wide open straights!)
NumberoftheBeast
Post by NumberoftheBeast » Sun Feb 10, 2008 12:47 am
Good choice. I appreciate the '6 is a thirsty beast and petrol is expensive, but given the possible complications that could incur, I think it's a good choice. Two and a half aint cheap either and like I said before, as opposed to spending that much in one go, you could just keep it in your pocked and it'll cover the fuel.
911 Turbo
Subaru Impreza WRX
ewill
Post by ewill » Sun Feb 10, 2008 3:44 am
skiwi wrote:i believe that lpg is 100ron - many cars make do without a modified ecu map, but i'd want to have this option with a hi-po car. the other big issue is range - just not anywhere as good as with petrol. also you lose a fair amount of usable space in the vehicle.
LPG is higher octane but lower specific energy than petrol. So without ECU mods, you'll use more LPG than petrol, but if you mod the ECU to take advantage of the higher octane then you'll get those losses back and perhaps more so on a twin turbo. But then you can't run on petrol, unless you have a multi program like those offerred by APR. LPG only cars can have starting problems, which means that installers often leave the petrol tank in and have the car start on petrol.
Overall, I wouldn't be doing this to an RS6
boff
Post by boff » Tue Feb 19, 2008 12:49 pm
Subaru are doing it to their turbocharged cars, and a friend of mine has gassed is S6, he is delighted, £40 from Wimbledon to Leeds and back. Not bad
Do your research, kits are getting much better.
Zero Drama
S4
Post by S4 » Sat Feb 23, 2008 1:02 am
I would go for it... but only go with one system.. Prins. the system in very good.
Darren
alangjones
LPG
Post by alangjones » Sun Feb 24, 2008 11:07 pm
Philestine for even thinking the word
rs999 on Blues and 2's
