Hello from Berlin with my RS4 B7
New to the forum? Say "hello"
Rick_RS4
Re: Hello from Berlin with my RS4 B7
Post by Rick_RS4 » Fri May 17, 2013 11:30 pm
sync24 wrote:
ProgLocker wrote:
Welcome along ProgLocker - Lovely looking motor and I love the stance. I am interested to see how you managed to get the front so low - I am running KWv3 coilovers with 8mm spacers and 255x35x19 tyres and one of my tyres [offside] rubs on the outside of the tyre. Have you had the arch lips rolled at all or are you running a very firm compression setting on your suspension to stop the rubbing and what tyres are you using?
Kev. :blackrs4:
im lower than this on the 19s and i think theres another rs on here the same, i have no scrubbing issues 4 up, you must have a problem somewhere or the ooffside is too low, not a large chap are you lol
Post by MikeFish » Sat May 18, 2013 10:51 am
Kev I think Rick has 6mm spacers and you have 8mm on the front. Not sure if that makes a lot of difference but if only one side is rubbing, the tolernace must be minimal and so 2mm may make the difference.
Post by MikeFish » Sat May 18, 2013 10:52 am
Or Rick is right and you ate too many pies. :biggrin3:
sync24
Post by sync24 » Sat May 18, 2013 9:43 pm
Well
1) I took the 8mm spacers off today and the rubbing has stopped
2) I am getting the arches rolled
3) JPH how helped me today is running 12mm and the rear and 10mm at the front on KWv2's but his is a little higher than mine
4) Once the arches are rolled I'll put the 8mm spacers back on and I should have no issues with rubbing and will be able to go lower.
5) I have eaten some pies in my time but not THAT MANY :biggrin2:
6) The rears will be dropped as well
Rick_RS4
Post by Rick_RS4 » Sat May 18, 2013 10:02 pm
theres nothing to roll on the arches, if anything its scrubbing on the arch liner
Post by MikeFish » Sat May 18, 2013 10:12 pm
Rick_RS4 wrote:theres nothing to roll on the arches, if anything its scrubbing on the arch liner
This is what I thought too.
sync24
Post by sync24 » Mon May 20, 2013 7:56 am
After a good look this weekend It's rubbing on the inside lip of the offside front wing - you can see where the paint has been rubbed down and there is a slight rub mark on the outside of the tyre. I am sure its the spacers that are the cause
sonny
Post by sonny » Mon May 20, 2013 11:31 am
sync24 wrote:After a good look this weekend It's rubbing on the inside lip of the offside front wing - you can see where the paint has been rubbed down and there is a slight rub mark on the outside of the tyre. I am sure its the spacers that are the cause
Agree, after seeing it, its def not the mudflaps as the sump guard is lower, this would be rubbing first.
Hope you get it sorted and nail this demon.
Post by MikeFish » Mon May 20, 2013 12:11 pm
Try a set of 5 or 6mm if you don't want to lose the spacers altogether. Like i said earlier, Rick is runnig 6mm without any rubbing.
Return to “Welcome Area”
