Hello there
New to the forum? Say "hello"
controversial
Hello there
Post by controversial » Sat Nov 28, 2015 8:16 pm
Just bought a sprint blue RS4 ... Few bits of advice needed
1. Steering wheel badge needs replacing
2. Flaps not opening in exhaust How do I just keep them open
All advice greatly welcome
993 RS
RS4 B7
Nononsense Chopper
Harley Davidson Fatboy Custom
birdiemachine
Re: Hello there
Post by birdiemachine » Sat Nov 28, 2015 8:21 pm
Unfortunately the badge cannot be bought separately and has to be bought as part of the entire silver lower section of the steering wheel. The wheel needs removed and dismantled to fit. See the following link for a guide : viewtopic.php?f=35&t=114654&hilit=steer ... el+removal
Regards the exhaust, i am almost certain they are springloaded so when the car is off and no vacuum they return to the open position, so you just need to removed the vacuum pipes from the exhaust but ensure you cap them off with some self tapping screws.
Welcome to the forum, get some photos up and FON
controversial
Re: Hello there
Post by controversial » Sat Nov 28, 2015 8:25 pm
awesome ...................THANK YOU SIR
993 RS
RS4 B7
Nononsense Chopper
Re: Hello there
Post by MikeFish » Sat Nov 28, 2015 11:33 pm
Welcome and FON.
If the flaps are shut when the engine is off then they are stuck and need a bit of force to open them. Spray a bit of oil or wd40 to loosen them up a bit and then force them open with a screwdriver or stick or similar. I think you need to push them at the top to open them.
Return to “Welcome Area”
