xenon headlight guru's/ vag com
Posted: Wed Mar 07, 2012 8:25 pm
by northern8019
i have a query, my RS6 avant is lowered on coil overs, and when i 1st got the car the lights pretty much shined down onto the road rather out giving me any distance. SHortly after this the MOT was due, so obvioulsy the lights were well out. so i simply used the manual adjustment to get me out of a pickle!
Im thinking now should i be taking it to an audi garage to get the lights setup both with manual and auto lamp adjustment.. As ive simply wound the lamp mounts upwards surely the light is still trying to achieve its pre-lowered settings??
so again audi garage/or can a slick
Vag Com owner sort this?
let me know thoughts etc
cheers
steve
Re: xenon headlight guru's/ vag com
Posted: Sat Mar 31, 2012 9:38 pm
by Ice_Coffee
the more normal method is to adjust the bracket for the 2 level sensors on the axles to counteract your lowering.
Posted: Sat Mar 31, 2012 9:47 pm
by Shoppinit
The car doesn't know the absolute level. Just the difference between front and rear.
As long as you stay within the acceptable range of the senders then you are fine. If not the you need to mechanically adjust as outlined above.
Posted: Tue Apr 03, 2012 8:24 am
by northern8019
Ice_Coffee wrote:the more normal method is to adjust the bracket for the 2 level sensors on the axles to counteract your lowering.
cheers for the reply, but how and where do i find/adjust this?
Steve
Posted: Tue Apr 03, 2012 8:29 am
by Shoppinit
This:
Posted: Tue Apr 03, 2012 10:36 pm
by northern8019
Cheers for the quick response, is there a how to for this? Or is it trial n error approach
Sorry for the newby questions :0)
Posted: Wed Apr 04, 2012 8:33 am
by Shoppinit
I don't think you need to do it. I have had my car slammed and it didn't affect the headlight leveling system. Your problem is coming from somewhere else. Probably need to reset the zero position with the
Vagcom and adjust the aim manually.
When you start the engine with the lights on, do they cycle through the max / min position? If you push down on a wing, does the aim stay the true?
Test all that first before messing aroudn with brackets.
Posted: Tue Apr 10, 2012 10:43 pm
by northern8019
Shopinnt
I take it you mean flick the light switch around to normal on position before turning on the ignition?
Is the Car meant to cycle to max n min positions?
Where an I best getting the headlight positions adjusted? Audi garage?
Steve
Posted: Wed Apr 11, 2012 8:14 am
by Shoppinit
Yes, if you start the engine with the lights on, you will see the level cycle from max to min.
Audi or VAG garage. Or somewhere with a
Vagcom who knows what they are doing.
Posted: Wed Apr 11, 2012 9:01 am
by northern8019
ill try my lights later, ill have a hunt about for other garages in south lake district area
cheers again
Posted: Tue Apr 17, 2012 7:41 am
by northern8019
is anybody aware of any
Vagcom garages/people in the NW/South lakes?
Posted: Thu Apr 19, 2012 7:25 am
by northern8019
Shoppinit wrote:Yes, if you start the engine with the lights on, you will see the level cycle from max to min.
Audi or VAG garage. Or somewhere with a vagcom who knows what they are doing.
alright mate, you mentioned about the headlight cycle, noticed it last night, yep it does that but one n/s light beam is much lower (potingin at road than the other)
think im gonna have to bit the bullet and visit audi garage
Posted: Thu Apr 19, 2012 12:28 pm
by Shoppinit
I had that after I went over a huge bump in the road. Something went out of whack. The headlights on these are a bit fragile. Check out the RS6 forum for the topics on headlights where we talk about it.
