RS6 GPS antenna dead, any new options?
Posted: Sat Sep 03, 2011 10:30 pm
by el_ringo
Hiya,
The GPS antenna on the car is dead again and I was wondering if there are any better options than getting an OEM one or adding another cheap antenna under the dash?
I would ideally like to to know if a modern antenna exits that is an improvement that could supply one or two devices.
I have an RNS-E and a B2 fitted at the moment.
Thanks,
R
Re: RS6 GPS antenna dead, any new options?
Posted: Sat Sep 03, 2011 10:49 pm
by PhilT
I've just opted for a dash one as a temp measure. Will be interested what people recommend.
Posted: Sun Sep 04, 2011 10:31 am
by PetrolDave
PhilT wrote:I've just opted for a dash one as a temp measure. Will be interested what people recommend.
That's what I'd go for - fit a hockey puck antenna underneath the plastic part of the dash (NO metal above it is important).
I've been using that for the last 6+ years and never had any problems.
Posted: Sun Sep 04, 2011 8:59 pm
by el_ringo
Did you juse use a cheap one from eBay or is there a premium brand to use Dave? The B2 sensor is tucked up in the corner like that at the mo.
Posted: Sun Sep 04, 2011 9:48 pm
by PhilT
Mine was one that I got with an Alpine head unit about 10th years ago!!
Posted: Mon Sep 05, 2011 7:19 pm
by PetrolDave
el_ringo wrote:Did you use use a cheap one from eBay or is there a premium brand to use Dave?
I just use the one that came as part of the kit with my original RNS-E back in 2005, nothing special.
Posted: Sun Sep 25, 2011 12:14 pm
by el_ringo
Not had a lot of other input, I have found two on eBay but is there a special connector to use?
http://www.ebay.co.uk/itm/SMB-GPS-Anten ... 4cf939217a
or
http://www.ebay.co.uk/itm/FAKRA-GPS-Ant ... 4cf13da8e0
Any ideas?
Posted: Sun Sep 25, 2011 4:25 pm
by PetrolDave
el_ringo wrote:Not had a lot of other input, I have found two on eBay but is there a special connector to use?
or
Any ideas?
You need the second one as the RNS-E has a Fakra connector.
Posted: Sat Oct 08, 2011 4:07 pm
by el_ringo
I got the Fakra one and it works well, just need to hide it in a good position later.
