Signal not good.
Posted: Wed Mar 03, 2010 12:27 pm
by BagginS4
Hi,
I recently fitted a sony headunit into my B5, now when I tune into a radio station the signal is really poor with lots of interference or cannot find the station altogether.
I know the aerial is built into the rear window, has anyone had this issue how did they get around it?
Bill
RE: Signal not good.
Posted: Wed Mar 03, 2010 3:19 pm
by craigyb
You need to supply power to the antenna with a phantom power supply for the antenna.
Like the ones on this page lower down
http://www.auto-connect.co.uk/VW.html
Posted: Wed Mar 03, 2010 5:02 pm
by BagginS4
thanks for that, so the blue wire coming off of the phantom power supply then connects to what?
Posted: Wed Mar 03, 2010 9:59 pm
by craigyb
+12V switched I would guess. If your radio has an electric antenna feed then that may be the wire to connect to, it should provide +12v when the radio is used.
Posted: Thu Mar 04, 2010 9:42 am
by BagginS4
Yep cheers thats sorted it, got clear signal now.
Thx.
Posted: Wed May 05, 2010 9:57 pm
by lindowkid
BagginS4 - what did you fit in the end ? I have the same problem and although its better with one of these adaptors the signal is still very weak..
