Ignition derived 12v supply
Posted: Wed Jan 28, 2009 5:01 pm
by MartynC
Is there a point under the bonnet of my RS6+ were I can easily connect to that will supply 12v (less than 1 amp) when the ignition is on? i can find this in the fuse box in the car of course but then need a route into the engine bay. Any help appreciated.
MartynC
RE: Ignition derived 12v supply
Posted: Wed Jan 28, 2009 6:19 pm
by craigyb
Under/behind the drivers kick plate you will find some metal bars, the one marked 75 is a switched live.
Posted: Thu Jan 29, 2009 1:00 pm
by MartynC
Craig that's most useful thanks. What is the best route into the engine bay? I'm fitting led running lights.
MartynC
Posted: Thu Jan 29, 2009 1:54 pm
by Blue_Thunder
Via the ECU box.
Posted: Fri Jan 30, 2009 8:18 am
by MartynC
Thanks Guys......I'll get onto it to get my front leds lit!
MartynC :D
Posted: Sat Mar 14, 2009 2:56 pm
by tartan_rob
There must be a ignition +ve from under the bonnet>>?
Posted: Sat Mar 14, 2009 5:19 pm
by MartynC
No doubt, but the bus mentioned is the right place and works well. Job done now, it drives a regulator (placed in the ECU box) for my LED driving lights.
MartynC
Re: RE: Ignition derived 12v supply
Posted: Tue May 05, 2009 8:30 pm
by gdavison
craigyb wrote:Under/behind the drivers kick plate you will find some metal bars, the one marked 75 is a switched live.
Help .. is this also available in the C6 RS6 ? and forgive my ignorance .. whats a Drivers kick plate?
