Will this work with my factory fit phone prep?
Posted: Sun Aug 31, 2008 12:08 pm
by elise135
iPhone holder
Audi iPhone blue tooth cradle only for vehicles with factory phone prep suitable for original and 3G iPhone. Holders available for other styles of phone please e-mail.
Order number: 8P0051435GP
Our price: 82.20 GBP
157.00 USD
plus 17.5% VAT
Hi. Just recently got my 2004 S4 and although it has the phone prep fitted I am not certain which version it is... the car has the navigation with the 2xSD card slots for music and the 6disc multichanger fitted..
Just wanted to know if the iphone holder listed above is compatible?
https://sslrelay.com/s74326199.oneandon ... 00x546.jpg
Re: Will this work with my factory fit phone prep?
Posted: Sun Aug 31, 2008 4:23 pm
by PetrolDave
elise135 wrote:the car has the navigation with the 2xSD card slots for music and the 6disc multichanger fitted..
The sat nav has no relevance to the phone module - they are completely separate, and the same phone modules are used with the "normal" radios like the Concert & Symphony.
I don't see why you need a Bluetooth cradle, since the module that the cradle connects to provides Bluetooth (unless you have a very old module fitted to your car).
So you don't end up buying something wrong, best to first get someone with VAG-COM to check the revision letter of the phone module (address #77) fitted to your car.
Posted: Sun Aug 31, 2008 8:54 pm
by elise135
PetrolDave wrote:elise135 wrote:the car has the navigation with the 2xSD card slots for music and the 6disc multichanger fitted..
Should the supplying dealer have that info somewhere in the system?
Posted: Mon Sep 01, 2008 9:45 am
by PetrolDave
elise135 wrote:So you don't end up buying something wrong, best to first get someone with VAG-COM to check the revision letter of the phone module (address #77) fitted to your car.
Should the supplying dealer have that info somewhere in the system?[/quote]
I doubt it, probably all they will have access to is the option code (which you've also got on the sticker in your car), and that doesn't change along with module revision codes.
Posted: Tue Sep 02, 2008 9:29 pm
by elise135
PetrolDave wrote:elise135 wrote:So you don't end up buying something wrong, best to first get someone with VAG-COM to check the revision letter of the phone module (address #77) fitted to your car.
I doubt it, probably all they will have access to is the option code (which you've also got on the sticker in your car), and that doesn't change along with module revision codes.[/quote]
Ok.. the local Edinburgh dealer have the cradles in stock and have put one aside for me, we are going to try it and if it doesnt work then they will put it back into stock.. so I cant loose..
