S4 ABS CODE
Posted: Wed Apr 16, 2008 8:40 am
by grizz
Does any one know what the coding should be on a b5 s4 2000 "w" reg , it's got esp .
Also it's got a code listed for the steering angle sensor ......
RE: S4 ABS CODE
Posted: Wed Apr 16, 2008 10:34 am
by PetrolDave
Clear the steering angle sensor problem by re-calibrating it - see the Ross-Tech website for the procedure - and the ABS fault will probably go away too.
RE: S4 ABS CODE
Posted: Wed Apr 16, 2008 10:41 am
by GardinerG
Hi Grizz, this should help: http://wiki.ross-tech.com/index.php/Aud ... ASR/ESP%29 Use the car's PR code for the brakes.
You need to login (using a non 0 workshop code), code it and then do the basic settings to set the steering angle sensor.
Grant
