A4 RNSE in A6
Posted: Tue Dec 25, 2007 11:55 am
by tattoo
Whats the difference between the a4 and a6 rnse unit been offered one for a good price and wondered if it will fit
ANY HELP!!!!!!!!!!!
RE: A4 RNSE in A6
Posted: Tue Dec 25, 2007 12:20 pm
by Virdee Autos
The faceplate on the A6 unit is slightly wider than the A4 unit, and also has a chrome strip at the bottom on the A4 unit. May even be different in height.
All depends on what your going to be using the unit for, i.e. B5 retrofit, or into a a4/a6?
RE: A4 RNSE in A6
Posted: Tue Dec 25, 2007 12:24 pm
by tattoo
ive got the standard cd based sat nav and was going to upgrade to the RNSE unit thought it was straight forwaRD SWAP
RE: A4 RNSE in A6
Posted: Tue Dec 25, 2007 12:36 pm
by Virdee Autos
Yes i'm pretty sure it is, but if your going to be putting the A4 unit in your A6, then your going to have gaps on either side, and not entirely sure about the height
RE: A4 RNSE in A6
Posted: Tue Dec 25, 2007 12:39 pm
by tattoo
Thanks think i'll just get the A6 version Much Simpler?
RE: A4 RNSE in A6
Posted: Tue Dec 25, 2007 10:47 pm
by Virdee Autos
Yes!
RE: A4 RNSE in A6
Posted: Thu Dec 27, 2007 12:06 am
by TDiAvant
Well this all depends on how cheap you are getting the unit, as you could buy the A6 faceplate and recode the RNS-E. It's also not a straight swap, you will need to get the can-bus wires from the instrument cluster, or if you have the TMC module fitted, then you will need to disconnect the TMC module and infotainment can-bus wires to the output can-bus wires. These will then need to be connected to pins 9-10 on the D connector of the RNS-E quad lock connector..
