Sat Nav disc copy
Posted: Wed Oct 31, 2007 8:07 pm
by tartan_rob
If I was going to take a back-up copy of my 2007 sat nav disc (for example), what would I need to do it? apart from the obvious dual layer DVD writer?
Can it be done and if so what type of discs? I have tried DVD-R DL and they don't work.
Posted: Wed Oct 31, 2007 8:21 pm
by AlexJ
I use DVD shrink to copy DVD's, not sure if it will work with a sat nav disc. You can download it free if you google it.
Might be worth a try!!
Posted: Thu Nov 01, 2007 10:27 am
by PetrolDave
The EU sat nav disc has a weird copy protection scheme. You can only make copies with certain drives, certain software and certain media - there's some (very) long posts on
www.navplus.us
Expect to make lots of coasters!
Posted: Thu Nov 01, 2007 12:23 pm
by AlexJ
I think DVD shrink gets past most copywrites, i've yet to encounter something it hasen't got past!!
Mind you there is always a first time..
Posted: Thu Nov 01, 2007 1:17 pm
by duncanhancox
despite what people say, there is no copy protection
-the disk is larger than 4.5gb, and most copy software gets the layer break wrong so the disks dont work
-the reader is fussy and will often only read verbatim dvd+r dual layer disks or disks using the same media type
-you dont need to copy at 1x or 2x - i have tried verbatim upto 8x and it works fine as long as the media is rated at that speed
what you need is:
a copy of clonecd - to get the layer break write
a pioneer dual layer dvd writer - i've tested an a07, a08. dvd109 and 110 models all with success
verbatim 8.5gb dvd+r genuine media - dont waste your money on other stuff, it wont work properly
good luck
Posted: Wed Nov 14, 2007 1:46 pm
by tartan_rob
Okay, I have the clone Cd software, my pioneer DVD writer and the verbatim dvd and nothing, it still fails. The DVD looks good, insert it and the sat nav unit says the disc is not comaptible with the audi sat nav.
Any ideas?
Posted: Wed Nov 14, 2007 1:57 pm
by ChipHazzard
it might be worth giving dvd decrypter a go
Posted: Wed Nov 14, 2007 2:05 pm
by duncanhancox
i tried about 12 different media types and any mkm 001 worked at 1x or 2.4x and any mkm 003 worked at 8x write without any problems at all
which pioneer writer are you using?
by duncanhancox
did you use verbatim dvd-r? they dont work - only the dvd+r work
Posted: Wed Nov 14, 2007 6:28 pm
by tartan_rob
Yep. DVD +r and pioneer 112d.
I can create the image with dvd decrypter but then I get an error when trying to write it, the actual copy button is disabled and the status bar says "Device not ready, Incompatible Medium installed".
I saved the image as ISO..
Any ideas? This is driving me mental.
Posted: Wed Nov 14, 2007 6:48 pm
by PetrolDave
Saw a post on
www.navplus.us that says to copy the sat nav DVD you need a region free DVD writer (RPC1 firmware).
Posted: Wed Nov 14, 2007 7:36 pm
by tartan_rob
The DVD writer is set to region free (or all regions), can't rememebr which.
rob
