Question for those with a "Connects2" adapter.....
Posted: Sat Oct 20, 2007 6:57 pm
by arS4
Hello,
Just got my Connects2 aux adapter. Plugged it all in. Sounds great......
Until you turn the engine on. A fair bit of engine whine in the background.
Any ideas how to fix it?
Dan
RE: Question for those with a "Connects2" adapter.
Posted: Mon Oct 22, 2007 12:36 am
by TDiAvant
Is the cable earth correctly? it's the most likely cause of interference
Posted: Mon Oct 22, 2007 11:48 am
by arS4
Well, I assumed that on the back of the stereo, there's the ISO connectors on the one side, the aerial on the opposite side and the an earth cable/connector just next to that.
I've attached the cable there......
Is this right?
Dan
Posted: Mon Oct 22, 2007 10:58 pm
by TDiAvant
The case of the head unit should be grounded so guess that's OK, but I would have connected it to the ground wire on the ISO power connector.
Posted: Tue Oct 23, 2007 9:15 am
by tdiquattro
They must have sent mine out on the same day!!!, fitted it on Sunday.
I have done exactly the same thing, earth on the small lead with the spade connector like you and no noise on mine.
I took the power from the switched power line to the changer, it is the (black/white i think?) wire next to the input wires fron the connects2, means it is powered only when you select CD, dunno why they didn't do that from the factory?
I put the switch in the top of the small cubby space near the drivers right knee below the steering wheel, there is already a hole in it the right size!!!
So I can't help except to confirm that earth is fine. I was surprised the cables werent screened though as it's low level audio.
What a great mod btw, superb, I should have done it months ago, I had one of those crappy tape pickup things till now.
Nigel.
Posted: Wed Oct 24, 2007 9:50 am
by arS4
Found out what the problem was. My connects2 is the just the inline RCA adapter one (doesn't use the power/data connector underneath the Ipod).
My Ipod charger was causing interference - so I'll need to get a ground isolator.
A few quid spend will confirm this though
Still, the sound now is much better than the ITrip
DAn
