Another TV AUX Question.....
Posted: Thu Jun 21, 2007 12:51 pm
by neily
Hi all - apologies if this has already been covered off in another thread...
I have just bought a 2001 B5 RS4 Avant with the OEM TV Tuner and CD Based SATNav+ system. Looking to add a couple of mods to keep the nippers quiet in the back....
1) make 'TV in motion' function - I understand this is just a case of disconnecting the GA white/blue lead from the headunit ??
2) As I understand it, as I have the non-B TV Tuner it should be able to use the AUX inputs for hooking up an external DVD Player (will also allow DVD's to be playe din the front once TV in motion has been resolved...
3) Am I able to create an additional OUTPUT for the OEM TV Tuner as I want to hook up additional screens in the backof the headreasts with the ability to view TV ??
Any help is GREATLY appreciated.....
RE: Another TV AUX Question.....
Posted: Thu Jun 21, 2007 3:19 pm
by shineydave
tv in motion is just a matter of snipping the GALA wire as you say, i've put a small pushbutton switch in the line so i can enable or disable it as required.
you can plug any video or audio source into the tuner and listen or watch by pressing the mode button when in TV to switch to the aux input and yes, it works whilst on the move too assuming you've cut the GALA wire
not sure about the third question, i think the answer is no but no doubt someone will be along soon who knows the definitive answe
Posted: Fri Jun 22, 2007 12:48 pm
by Dippy
Posted: Fri Jun 22, 2007 1:28 pm
by neily
Nice one Dippy !!! - answers my (many) questions in 1 easy swoop !!
Posted: Fri Jun 22, 2007 1:42 pm
by theaxe
Note that snipping with GALA wire will greatly reduce the accuracy of the satnav so a switch as ShinyDave suggested would be a good idea.
Posted: Fri Jun 22, 2007 2:01 pm
by craigyb
Actually on the RNS-D, that gala wire is only used for the speed sensitive volume and can be cut without affecting the navigation, as the RNS-D has two feeds.
This is a problem with the RNS-E in an A6 etc as it has only one feed.
Posted: Sat Jun 23, 2007 8:23 pm
by shineydave
thought mine still kept pace with the location of the car ok, i couldn't see any difference with the button on or off. i only fitted a switch in case of a tug by plod when the TV was on
Posted: Mon Jun 25, 2007 1:09 pm
by Dippy
I have a switch because I like having speed-sensitive volume control!
IIRC the issue is that the RNS-D was fitted to a range of models, and there are SOME cars which do have a nav problem when the gala connection is removed.
Another reason to fit a switch is in case of an accident and the investigator discovered that the gala wire was permanently disconnected, and we all know how insurance companies never try to avoid paying up do they?
Posted: Mon Jun 25, 2007 2:44 pm
by neily
Ok guys, I'm REALLY struggling getting the SATNAV+ HU out.... :oops:
Looks like the top right clip is not dis-engaging....
Is it possible to get to the back of the HU be removing the whole centre console, or at least attacking the side of the console ??
Any help is really appreciated....
Posted: Tue Jun 26, 2007 12:24 pm
by Dippy
No, I don't think you can. I had difficulty removing my HU. There is a certain technique you need with the keys and so I'd just recommend that you persevere.
Posted: Tue Jun 26, 2007 12:50 pm
by lengster1
Try easing a bank card round the edges coated in vasaline or similar,it will help break the seal and assist it popping out,makes a change from vasaline assisting popping things in ha ha,try popping one side at a time rather than getting both sides ot the same time,patience is a must those little keys scratch the unit easily as my main agent proved !!!!!!!
Posted: Tue Jun 26, 2007 1:01 pm
by neily
Ok thanks. I will get my flexible friend out tonight with the large tub of vasaline.....
BTW - i have no idea what you're talking about re another use of vasaline ?!?! :oops:
