Is my Concert headunit dead?
Posted: Mon May 28, 2007 2:29 pm
A while back I was doing some work on the car and needed to take the faceplate off the centre console. I was told by a friend that it would just pull off, so when I gave it a good tug, the tabs behind the stereo front snapped.
The problem is that ever since, the stereo won't turn on. I pulled the stereo out the other day and am pretty certain i've found the culprit. There was a £1 coin rattling about inside. I'm guessing that when I've yanked the faceplate around the stereo, i've dislodged the coin and it's shorted something inside the stereo.
The fuses are all ok, infact when I try to run a Vagcom check the cassette motor spins a little bit proving that it's still got power. Vagcom doesn't show anything because it fails with "too many communications errors".
Is it time to look for a new stereo?
