Update for Sat/Nav+
Posted: Wed Feb 21, 2007 9:07 pm
by cpt_splash
I just bought a new CD for UK & Ireland 2007 for my Navigation Plus DX system in my 2000 RS4. I bought the version with the iTMC for updated traffic reports. This did not work in my system. Do I need a software update, or do I need to buy the version with iTMC? Thanks in advance. Graham
Posted: Wed Feb 21, 2007 9:57 pm
by Jarv
Is this the one you bought:
http://www.navshop.com/en/product/unite ... 3280/101/1
It's the one I bought about three weeks ago, stuck it in and it worked. Is your tuner working OK? The iTMC reports are received via Classic FM, which it tunes into in the background.
Posted: Wed Feb 21, 2007 11:21 pm
by cpt_splash
Yes, it is the same one in your link. It siad that it could not read the CD. I put the old 2002 version back in and it worked fine again. :evil:
Posted: Wed Feb 21, 2007 11:22 pm
by cpt_splash
Do I need to have Classic FM running first when I put the CD in? I can't believe that you have to do that....
Posted: Wed Feb 21, 2007 11:48 pm
by craigyb
Do you have the RNS-C and not the D?
Posted: Wed Feb 21, 2007 11:53 pm
by cpt_splash
How would I find out? It is fitted to a 2000 X reg RS4.
Posted: Wed Feb 21, 2007 11:59 pm
by Jarv
No, you don't need Classic FM running at all. You're in safe hands with Craig, he knows his stuff.
Posted: Thu Feb 22, 2007 1:25 pm
by Dippy
RS4 should have RNS-D if it was an OEM fit.
Re: Update for Sat/Nav+
Posted: Thu Feb 22, 2007 4:24 pm
by PetrolDave
cpt_splash wrote:This did not work in my system.
What was the exact error message you got?
RE: Re: Update for Sat/Nav+
Posted: Thu Feb 22, 2007 10:30 pm
by Carps
I had a similar issue recently. It would read my old disc, but not my new one.
I fixed it when I pulled the navi unit and cleaned the laser. It's been fine ever since.
Might be worth a try...
Posted: Fri Feb 23, 2007 1:18 am
by cpt_splash
The error message said that the "CD could not be read. Please insert correct CD". Not very helpful!!! Problem was that as the CD would not read, no functions would work except eject CD. Once the old one went in, it was fine. Arrghh!!!
Posted: Fri Feb 23, 2007 1:20 am
by cpt_splash
cpt_splash wrote:The error message said that the "CD could not be read. Please insert correct CD". Not very helpful!!! Problem was that as the CD would not read, no functions would work except eject CD. Once the old one went in, it was fine. Arrghh!!!
How did you clean the laser?
Posted: Fri Feb 23, 2007 10:24 am
by Carps
To clean the laser you need to pull the navi unit from the dash and then use a cotton bud and alcohol (medical - not Vodka !) down the access hole in the top of the case.
Maybe better/less effort to try a cleaning CD first ?
