Can you change the faceplates on Navigation plus?
Posted: Sat Oct 21, 2006 10:48 pm
by keithly33
I have a navigation plus for an Audi A4 B5 which is not working. If I buy one for an A6 can I swap the faceplates without causing a problem ?
Thanks.
Keith.
RE: Can you change the faceplates on Navigation plus?
Posted: Mon Oct 23, 2006 10:20 am
by peterb
Yes, the faceplates can be changed fairly easily.
Posted: Mon Oct 23, 2006 7:23 pm
by keithly33
Thanks. :D
Posted: Tue Oct 24, 2006 2:20 pm
by Dippy
Hmm, my memory of changing my faceplate over does not quite match Peter's use of the words "fairly easily". Not as difficult as removing the aircon control unit but not far off! The trouble is that to pull off the fascia you need to depress 4 lugs simultaneously, and also the hole is exactly the same size as the unit, so there is virtually no room for manoeuver!
