Phatbox - engine noise
Posted: Mon Jul 31, 2006 1:08 pm
by Dippy
Although it has probably been there since I first installed it, recently I have been noticing that my Phatbox is cleary more susceptible to interference from the engine that the OEM CD changer was. During quieter music, I can hear a feint high-pitched hum which changes note with engine revs.
Is there an easy way to cure this?
RE: Phatbox - engine noise
Posted: Mon Jul 31, 2006 1:22 pm
by SimonS4MTM
I am not an expert by no means, so I am sure someone else can give you better advise, but I am sure you can buy interference suppressors from Halfrauds. I think they go, in-line with the 12V feed.
Posted: Tue Aug 01, 2006 10:19 am
by peterb
Yes, the noise is there, but not really intrusive. It sounds, to me, like it's alternator-generated. Whether it's getting in via the power supply line or the signal lines back to the H/U, I'm not sure.
I fitted the PhatBox when the car was about a week old, so I can't really compare with the OEM changer.
A thought - I wonder whether the PB electronics are grounded to the metal case. It might be worth experimenting with tying the 0V line to the chassis.
Posted: Tue Aug 01, 2006 12:21 pm
by Dippy
I agree, sounds like alternator interference. You may be onto something about the grounding. I think the case is aluminum, so the shielding won't be as good as the CD changer. So you just live with your noise?
Posted: Tue Aug 01, 2006 6:32 pm
by peterb
I do just live with the noise - sometimes I notice it and it niggles, but most of the time it isn't really obvious.
Posted: Tue Aug 01, 2006 7:31 pm
by jeffw
Get a Bosch Motorsport fuel pump fitted or a full Milltek.....any hum on the phatbox is swamped by the noise of fuel pump or exhaust :)
Posted: Wed Aug 02, 2006 12:56 pm
by Dippy
My kids make more noise than my full Miltek :)
Still waiting for a positive reply...
Posted: Fri Aug 11, 2006 4:03 pm
by DrB
I notice it my car also. Mainly if the volume is turned up for poor quality recordings. Oh well....
Phatbox
Posted: Thu Sep 07, 2006 9:41 am
by itaggart
Apologies for my ignorance on ICE, but what exactly is a Phatbox?
Re: Phatbox
Posted: Thu Sep 07, 2006 10:17 am
by ChipHazzard
itaggart wrote:Apologies for my ignorance on ICE, but what exactly is a Phatbox?
Basically it's a boot mounted 20gb MP3 player that replace's the CD player and is controlled via the head unit
RE: Re: Phatbox
Posted: Thu Sep 07, 2006 4:09 pm
by tartan_rob
You could insulate the mounting points of the Phatbox and then fit a suppressor..? Or listen to Metallica 'One' all the time..? :rocker:
RE: Re: Phatbox
Posted: Sat Sep 09, 2006 9:04 am
by sitas3
A bit late to this thread but Dippy I also have this on my S3 whereas there was no noise using the inbuilt CD player. Its not something I'm worried about so have left it as-is for a year now.
RE: Re: Phatbox
Posted: Mon Sep 11, 2006 2:04 pm
by Dippy
Looks like we all put up with it then!
RE: Re: Phatbox
Posted: Thu Jun 18, 2009 6:54 pm
by tartan_rob
This is pissing me off. I have a suppressor but no idea where to put it as the RNSE take an earth from the aerial. How about a seperate heavy earth directly onto the RNSE case?
RE: Re: Phatbox
Posted: Tue Jul 28, 2009 6:28 pm
by tartan_rob
There is no obvious earthing point....and an additional earth does not work...
