29 satellites available , 0 Connected
rs4-sson
Post by rs4-sson » Sat Jul 01, 2006 11:46 pm
Guys
Haven't been able to get the car to "find" its GPS position. Did some checking in the Settings / GPS viewer and found that I'm not connected to any satellites at all eventhough the system says there are 29 available. Anyone know where to look for the fault before it goes to the local stealer?
I don't have VAG COM (and don't know anyone who does) so haven't tried to see the fault code.
If I need to replace something - which part of the SatNav system would it be? The GPS receiver part I guess but does it have a formal name?
Thanks for your help
derdle
RE: 29 satellites available , 0 Connected
Post by derdle » Tue Jul 04, 2006 8:17 pm
I think there are only 29 GPS satellites up there in total...and a GPS system can only ever see a few of them - perhaps 6 (not too sure on the figure) as the rest of them will be below the horizon.
Don't know what will need looking at though - sorry.
Paul
rs4-sson
Update
Post by rs4-sson » Sun Sep 10, 2006 7:29 pm
Hi guys
I'm still having this problem but can share the following new information.
Disconnected the battery - left it overnight and re-connected - Now the GPS Viewer setting says there are 32 satellites but that I am receiving 0 of them - "Geographical location could not be establed"!!
Took the car to Audi - diagnostic machine couldn't find a single fault with the Nav system or the antenna, the tech was as stumped as I was!
After following advice on other Nav fora, I have just updated the firmware to Nov 2001 version - this did not help. Still not able to pick up a single satellite so am constantly "lost" somewhere 100kms north!!!
This is a nightmare - any ideas anyone?
HGH
RE: Update
Post by HGH » Sun Sep 10, 2006 10:01 pm
Try it with another antenna, a vdo / blaupunkt will fit.
rs4-sson
Post by rs4-sson » Sun Sep 10, 2006 10:06 pm
Hi
Forgive me for being dense - but what do I actually need to replace. Is it the twirly bit that screws off or would it be the whole unit (including cable)?
Any pics explaning how to do this? Where can I source an antenna from?
Sorry for the questions here but I am not on familiar ground.
derdle
Post by derdle » Mon Sep 11, 2006 8:53 am
I am confused...because I didn't think that any PS system could see 29 or 32 satellites ... I thought the maximum number in possible view at any one time was 8 or 10 (cos you can't see those below the horizon). Sounds like a software fault to me. It's not run on Windows ME is it?
Are you able to disconnect the antenna from the Nav unit and plug it into another GPS receiver (eg Road Angel or other camera detector or better still another sat-nav system (Tom Tom etc)) .. this will then show that the receiver is or is not working. Perhaps the aerial cable has broken?
Paul
ChipHazzard
Post by ChipHazzard » Sat Dec 09, 2006 3:36 pm
My sat nav has just developed the same problem, did you ever get to the bottom of it ????
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
ChipHazzard
Post by ChipHazzard » Mon Dec 11, 2006 10:43 am
I've been doing a bit more investigation over the weekend and narrowed it down to either the cable or the ariel by taking the head unit out of the dashboard and plugging in another GPS ariel and bingo it picked up straight away.
Does anybody know how the cable routes back to the ariel and if there's any plugs in line
Mike
FL Noggy S4 Avant
Nige_RS4
Post by Nige_RS4 » Mon Dec 11, 2006 1:21 pm
My GPS antenna failed on my old S4 - gave the same symptoms! I replaced it for around £45 for an OEM one and fitted it myself (Audi also failed to diagnose it correctly). You need to gain access to the bottom of the GPS antenna by removing the headlining and there is a single nut which holds it on.
HTH
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
ChipHazzard
Post by ChipHazzard » Mon Dec 11, 2006 1:53 pm
Cheers Nige, I had the base unit off over the weekend by popping out the rear light in the head lining and unbolting it that way, there's 3 cables coming out of the base, is there a connector handy to disconnect and swap them over or is it a case of out with the soldering iron ??
FL Noggy S4 Avant
Nige_RS4
Post by Nige_RS4 » Mon Dec 11, 2006 2:37 pm
The connector is under the headlining, but I noticed that all three antenna leads (radio, gsm & gps) had different length tails on them. No need for a soldering iron.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
ChipHazzard
Post by ChipHazzard » Mon Dec 11, 2006 2:40 pm
cheers, I'll have a look when I get home if it stays dry
FL Noggy S4 Avant
Return to “Electrical”
