Problems fitting Audi Sat Nav unit into RS4
Posted: Thu Apr 20, 2006 7:12 pm
Looking for some help!!!
I have a 2001 X Reg Audi RS4, it had the original Symphony unit in with 6 Disc in the boot.
I have bought a Sat Nav Plus unit from Good Old Ebay and am trying to get it to work, I have plugged it in, all the plugs are used as the oringal unit except a 10 pin red plug which only had a couple of wires going to it. The unit turns on and you can enter the code which I have done, I then get a message in german saying : SAFE - pin nicht angeschlossen, which when i've translated on the net comes out as 'SAFE - pis not connected.
Can anyone explain, do I need to connect something else to the unit or does the unit need coding to the car.
Any help would be greatly appreciated!!!
I have done a similar swap on an R32 and the unit powered straight up and worked perfectly.
Thanks in advance!!!
