Audi Sat Nav + Aftermarket DVD CHANGER INSTALL HELP!
Posted: Sat Nov 26, 2005 7:12 pm
Hi guys how you doing? Im new to the forum, so just seeing how it goes....
Just a little bit of advice needed...
Fitted a SAT NAV + aftermarket installation into my audi s3 2002
Didnt, have the tmc tuner box, or the tv tuner.....
PROBLEM 1: Get this warning when ever I switch on the unit...."the tmc connection to rds-tmc tuner is faulty or could not be established"....have been told, I can program the unit not to look for the tmc, if this can be done, how could I do it? instead of just fitting the tmc.
PROBLEM 2:
Brought a 6 disc dvd changer, and a multimedia adapter made for audis to view on Sat Nav +
Just wanted to ask, what button to I select to actually "SEE" the input....???
I have wired all the stuff up....but not actually even sure, if a 6 Disc DVD changer will be compatable, but then I thought about it
and thought that its not directly hooked up to the sat nav +, its signal goes into the adapter first, then through there into the unit..
PROBLEM 3:
This is the unit I brought, thought everything would be fairly easy, but having trouble with the signal, not sure if its getting there..
http://cgi.ebay.de/MULTIMEDIA-ADAPTER-2 ... dZViewItem
Any help is appreciated GUYS
Thanks.
PROBLEM 2:
PROBLEM 3:
Thanks.
