Will this fit an RS4 ???
Posted: Fri Nov 11, 2005 3:41 pm
by RS-Steve
Gents,
advice please on whether or not this will fit a 2001 RS4 :-
Audi Navigation plus RNS-E DVD System catalouge number 8E0 035 192 D
thanks in advance,
RS-Steve
RE: Will this fit an RS4 ???
Posted: Fri Nov 11, 2005 5:24 pm
by craigyb
Better off with a 4B0 035 192 P for an RS4, they fit better where the symphony comes out, but still leaves a small gap at the edges.
Posted: Mon Nov 14, 2005 1:41 pm
by Dippy
If you want a perfect fit without having to do mods, you need an 8D0 035 192 x, which are the old CD-based units. If you have your heart set on a DVD unit, expect to have to do some extra work to fit it.
Posted: Mon Nov 14, 2005 2:40 pm
by prof
Hi,
will a unit with a part no. of 4B0 035 192 F fit ????
also what do you mean by extra work ???
cheers,
Posted: Sat Nov 19, 2005 12:30 am
by gIzzE
Be careful with the different models, the 8E0 from a b6 takes the speed pulse from the canbus, where as a 4B0 unit can take it from the gala signal, which is what you want with the B5.
Get in touch with craigyB on the
www.tyresmoke.net forum, he will tell you what you need exactly, he can fit it all for you if you want too, he has put them in A2s etc. that never had them either.
Posted: Sat Nov 19, 2005 12:32 am
by gIzzE
Actually, just seen the next post and see Craig is on here too, forgot he has an RS6 now.
http://www.rs246.com/index.php?name=PNp ... ic&t=50903
Posted: Sat Nov 19, 2005 11:09 am
by RS-Steve
thanks,
i've sent a PM to craigyB asking for info re part numbers etc.
cheers,
RS-Steve
Posted: Mon Nov 21, 2005 1:53 pm
by Dippy
Prof, there are two issues:
1) The fascia
2) The electrical connection
A B5 S4/RS4 can only take an 8D0 unit without any significant work.
It can take a 4B0, 4D0 or even a 3L0 but needs the fascia trimmed or gaps filled. Ideally you need either a custom fascia or one from an 8D0.
It can take an RNS-E 4B0, but still needs some fascia work and maybe some wiring changes (Craig knows about it)
It can take an RNS-E 8E0, but still needs some fascia work and won't function correctly without a CAN interface
If you really want the OEM look without much effort, you need an 8D0 unit
