Audi Antenna To be powered or not be powered?
Posted: Fri Mar 11, 2005 5:15 pm
Hello,
Trying to get a sensible answer to a question, I have changed my Concert Head Unit in my S3 (as well as adding a couple of amps, subs, components - pictures of install progress available).
on the way home from the Car Hifi shop, I yoinked the Concert out and plugged the new Apline head unit in. I listed to the radio on the way home - all very nice.
The only thing is now after fitting everything properly I cant get any signal on the radio at all!!! unless...i stick a screwdriver in the headunits antenna plug and use me as an antenna! If I touch the screw driver with the middle pin from the car antenna - this signal is killed.
Someone must now what the crack is?
