TV on Nav Plus whilst moving
Posted: Tue Jan 04, 2005 3:20 pm
by Jeeves
The question must have been asked before, but I can't find the answer and would be grateful if anyone can enlighten me.
Now the kids know there's a TV, they want to see the screen (and not just hear it) on my Nav Plus.
Found a site
www.tectronics.com/tectronics which offers a 50 Euro box of tricks, but payment is in advance and they don't show any way of connecting it (except pictures of a more expensive device for BMWs).
Anyone know anything?
RE: TV on Nav Plus whilst moving
Posted: Tue Jan 04, 2005 3:37 pm
by Dippy
Assuming you don't have the DVD version (which has this feature controlled by CAN and therefore is not simple to turn off), then you just need to remove the GALA signal from pin 1 (IIRC) of the main ISO connector. Since this GALA signal also controls the volume-increase-with-speed feature, it is common to use a switch so that this can be restored for CD and radio.
Posted: Tue Jan 04, 2005 4:56 pm
by Jeeves
Thanks Dippy.
But Martyn C has quite rightly reminded me that mine's DVD based. That probably rules out the Tectronix box then.
Posted: Sun Jan 09, 2005 8:38 pm
by simple1
erm, forgive me if i am wrong here, but CAN is part of the system that lets all the ECU's talk to each other, therefore in the DVD based systems, the volume and screen control are triggered by one of several ecus and not by the yellow/pink wire
Re: RE: TV on Nav Plus whilst moving
Posted: Mon Jan 10, 2005 2:09 pm
by peterb
simple1 wrote:erm, forgive me if i am wrong here, but CAN is part of the system that lets all the ECU's talk to each other, therefore in the DVD based systems, the volume and screen control are triggered by one of several ecus...
Indeed, but disconnect the CANBUS and you lose ignition on/off signals, lighting signals etc. Also, the HU will power down after a little while of not receiving signals on the CANBUS.
A guy on Tyresmoke has built a little circuit to establish CANBUS communication momentarily every little while - this keeps the system running but disables the screen blanking.
Posted: Mon Jan 10, 2005 6:01 pm
by Dippy
Jeeves wrote:Thanks Dippy.
Not necessarily. As has been pointed out, the Nav unit learns that the car is moving by signals on the CAN bus. It would be possible to put a CAN-enabled device in line with the unit which would filter out these signals. It wouldn't necessarily have to be that expensive either.
I suggest you ask the company in question. By putting some English on their website it suggests that they welcome English-speaking customers...
RE: Re: RE: TV on Nav Plus whilst moving
Posted: Mon Jan 10, 2005 9:27 pm
by JohnW
building a can bus device is a piece of p!ss, the hardware to do it costs at most a couple of quid.
The best way is to try to get the correct connectors so the loom doesn't need to be butchered and plug it in-line.
After that it is simply a case of scanninng the bus to determine what messages are flying about, and filter out the ones you are concerned with, possibly spoofing false acknowledgments.
If I had the time I'd build one, but I haven't unfortunately. I will see if I can plug a CANalyser in at some point and log the activity though. Can anyone tell me the pins to monitor and the easiest place to get at them ?
Cheers,
John. (lots of knowledge of CAN
Posted: Tue Jan 11, 2005 1:48 pm
by Dippy
Surely on the car in question the diagnostics port is CAN based?
On an older car I think the easiest way to get at the CAN is at the Sat Nav head.
Posted: Tue Jan 11, 2005 2:45 pm
by JohnW
It may well be dippy, but I don't think it is. I am pretty sure the diagnostics port is not CAN based as it uses a standard serial (rs232) interface. The only special thing about the lead is the connector.
CAN is a differential signal (similar to RS422, RS485, or I2C) and needs a specific node termination in order to connect to the bus. This is normally done with a 'CAN interface' chip. The cheapest way to get one of these is to buy a Microchip PIC microcontroller with a CAN interface on board.
The diagnostics port generally don't plug striaght onto the bus to ensure that if the car bus is shorted/open circuit at least diagnostics can be used to report the loss of connection.
I think your right though, satnav head or clock display is possibly the easiest access point.
Posted: Wed Jan 19, 2005 12:07 pm
by Jeeves
Question asked in English, but so far no response. Wieder, aber jetzt in Deutsch denke ich. Will keep you posted.
(Did see another thread re older Nav system on A2 etc, it's on p3 or 4 of RS6 forum for anyone interested.)
Posted: Wed Jan 19, 2005 2:48 pm
by Dippy
Erwähnen Sie nicht den Krieg...
Posted: Thu Jan 20, 2005 3:56 pm
by Jeeves
Don't mention ze war......
Posted: Fri Jan 28, 2005 10:59 am
by Jeeves
You may have already found this anyway, but apparently there's a Dietz 1280 unit which does the trick and can be found for < 199 Euro on Ebay. Someone in the US offers a plug and play version of the same, but doesn't take international orders. Anyone know anymore?
